removing lt1 heads
Old Aug 5, 2005 | 10:39 PM
96KillaZ's Avatar
removing lt1 heads
How hard of a job is this, how many hours. What else should I change while they are out? Are there any good sites out there that shows how to do it? I plan to take out my heads soon and send them out to get ported by loyd elliot so any info would be great. Thanks
Old Aug 5, 2005 | 10:43 PM
blackztpi's Avatar
Re: removing lt1 heads
its not bad, but like everything else i guess. some people pull them in an hour and some take 2 days. i followed the shbox.com guide for the cam removal. this shows you the steps to get everything undone on the top end. obviously, ignore the removal of the waterpump, timing chain and optispark. it got me where i needed to go.
Old Aug 6, 2005 | 12:38 AM
simple's Avatar
stock cam? if so, you'd be better off swapping cams before pulling the heads for porting
and FYI, it can be of benefit too buy a set of used heads from someone too send off for porting and when they are done and you have them back, pull yours off and sell them. this really saves on down time
Old Aug 6, 2005 | 06:30 AM
Bawls's Avatar
I replaced both of my head gaskets in about 8 hours said and done. This was spread out over a couple months though while the car was down. But the time spent on the heads alone were about 8 hours, not knowing what I was doing. Now I'd say maybe 4 hours for both sides said and done. As long as they've got headers.
Old Aug 6, 2005 | 10:31 AM
96KillaZ's Avatar
I have the xe224/230 cam. and every bolt on, porting the heads will most likley be my last mod
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
