Removing Intake Manifold right now...few quick questions.
Old Sep 28, 2004 | 02:10 PM
95BlackTA's Avatar
I have Seafoam and brake clean, will any of those work to clean the inside of the intake once I get it off, or do I need carb cleaner?
Also, what should I put on each of the intake bolts when I put them back in there? I have some blue silicone gasket stuff that I used when installing my waterpump...says its oil resistant and crap, would that work? Or do I need something else to hold them in there?
Old Sep 28, 2004 | 02:27 PM
LWillmann's Avatar
Re: Removing Intake Manifold right now...few quick questions.
I believe you use a little bit of red Loctite on the bolts. And I used TB & Intake cleaner when I had my manifold off.
You could also take it to a machine shop and have it steam cleaned or boiled to clean it out.
Old Sep 28, 2004 | 02:31 PM
95BlackTA's Avatar
Damnit I cant get to the Very back driver side bolt..Theres a ****ing Flying saucer looking thing bolted onto the back of the intake, and I cant get my socket in there. Can I removie this thing, or will I need a new gasket for it if I do? Im trying to get a normal wrench in there but I cant get enough leverage to break it loose.
BTW im pretty sure its the EGR valve thing, but I have my EGR bypassed..so I guess its jes chillin back there? The previous owner bypassed the EGR so im not sure how all that works. I jes looked and my pack of gaskets that I have a "EGR valve pipe" gasket....thats the one right?
Old Sep 28, 2004 | 02:50 PM
OBE1 95Z28's Avatar
The EGR valve will unbolt if it's in your way. The EGR tube gasket is a different gasket; it's the tube on the passanger side that goes from the back of the intake to the exhaust manifold.
Old Sep 28, 2004 | 03:12 PM
95BlackTA's Avatar
Well I got the intake off...now how exactly do I clean it? Theres another small pan held on by 4 bolts that I jes took off, but theres not much under it. Do I jes get card/intake cleaner and spray it all down into the intake and let it run out or what?
Noer
Feb 28, 2015 11:29 AM
alex5366
Feb 17, 2015 08:12 PM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
