Removing intake manifold...
Old Jul 13, 2003 | 05:14 PM
NAZTLT1's Avatar
Okay, this thing is very stubborned. I can see seperation along the driver side but the pass side ain't budgin'. What's the best way to break it loose without messing up the heads or the valve covers?
Old Jul 13, 2003 | 05:31 PM
I burn rice too's Avatar
Try getting a paint scraper and wedge it between the manifold and the head, then tap it gently. Once you get it going most times it will come off easy. you can also take a rubber mallet and just hit hit gently, that works too. Are for sure that all of the bolts are out?
Old Jul 13, 2003 | 05:32 PM
Josh-'04 GTO's Avatar
Make sure you have all the bolts out(could happen!). Then take a rubber mallet and give it some taps to see if it will loosen up. Or take a pry bar and gently work it loose.
Old Jul 13, 2003 | 05:34 PM
NAZTLT1's Avatar
12 bolts right? And I will try the scraper .
Old Jul 13, 2003 | 05:35 PM
Super Slow '97's Avatar
There should be a little nub sticking out of the front passenger side towards the front pry there with a pry bar and it will pop right off. Matt
Old Jul 13, 2003 | 05:37 PM
NAZTLT1's Avatar
Superslow I tried that and rounded the soft metal so the pry bar won't grip. But thanks.
Old Jul 13, 2003 | 05:57 PM
NAZTLT1's Avatar
Talking
Got it, Thanks guys.
ModdedNerd
Jan 29, 2015 07:23 PM
rjc1629
Jan 27, 2015 10:46 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
