Removing A.I.R.
Old Sep 26, 2003 | 09:27 PM
  #16
jasons93z's Avatar
How do you remove ALL of the EGR stuff? Thanks.
Old Nov 25, 2003 | 01:16 AM
  #17
Blue96z28's Avatar
Originally posted by MrBigXL
the AIR air pipe needs to be cut in 2-3 places to remove it
i still have part of it hanging near the block on the pass side
need to make 1 more cut or something
anyone know if it's bolted to something else? it feels like it
Its polted onto the back of the compressor w/a small hold down, nothing needs to be cut in order to remove the air lines, all of them come out with a minimal work.
Also, some on told me to use a m18 metric plug to plug the manifolds, this was slightly smaller than it should be but still tightened up completely, put for the record it is the WRONG size.....
You might gain more than 7pds with all that, there's a HUGE alum. braket behind the airpump that can be removed as well......
Old Nov 25, 2003 | 07:00 AM
  #18
IslandZ's Avatar
http://www.zmydust.com/airpump.html
Instructions on removing AIR and EGR.
Old Nov 25, 2003 | 01:49 PM
  #19
Blue96z28's Avatar
There must be some differences in the AIR systems of different years, my 96 has only a short peice of metal tubing, going from the passside manifold to the crank pulley, from their it goes back up to the other side as a rubber hose, all looks factory????And i took it out without cutting anything, so i dont know???
greenzee28
Sep 25, 2015 04:29 PM
Jake Bialke
Sep 24, 2015 11:31 AM
wbspoon
Sep 19, 2015 08:12 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
