Removing Engine
Old Oct 6, 2004 | 12:27 PM
Black Venom's Avatar
Removing Engine
Ok I've got everything off and disconected, Except for the tranny. Now where it connects to the engine, I've got everything except for one bolt undone, the problem is that bolt. It's the driver side top bolt, I just can't even get my hands in there. I was able to get it a lil out with a wrench, but now it wont fit.
Please give me ideas, am I disconnecting it at the wrong spot?
Old Oct 6, 2004 | 12:50 PM
Dave88LX's Avatar
Re: Removing Engine
Yeah that bolt's a bitch!
I believe I used a swivel socket (not socket + swivel). You could also try pulling down a little on the tailshaft of the trans, or also putting a prybar up there and giving yourself a little room.
Old Oct 6, 2004 | 12:53 PM
Re: Removing Engine
Ah N/m I got really pissed off and almost took off my hand but I've got it
Now about that clutch fork...
Old Oct 6, 2004 | 12:54 PM
ulakovic22's Avatar
Re: Removing Engine
Use two or three long extensions and your socket and slide it in from the back next to the tailshaft. Trying to use a small wrench will take a long time cause you don't have any room to turn it really.
Old Oct 6, 2004 | 12:56 PM
izzyz28's Avatar
Re: Removing Engine
Pry the clutch fork off of the TOB. You'll feel it disengage, and then the tranny/engine should slide right out. When you pry on it make sure you are prying it STRAIGHT. It can be pretty tight, but it shouldn't take too much effort.
Old Oct 6, 2004 | 01:17 PM
Dave88LX's Avatar
Re: Removing Engine
Yep it should pull straight OUT.
DirtyDaveW
Dec 1, 2016 05:37 PM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
centric
Aug 15, 2002 09:04 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
