removing the egr valve
Old May 4, 2003 | 01:15 PM
weaponZ's Avatar
when removing the egr valve in a 94 Z, we have made a plate to remove it. Now what do we do with the egr sol valve. Do i remove that too and plug the vacum line at the maifold, or just remove the egr valve itself and leave the electrical sol valve hooked up and plug the vacum line from it?
thanks
Old May 4, 2003 | 04:20 PM
PoorMan's Avatar
Not really following you here. I put block off plates on both holes in the back of the intake. I took the EGR diaphram off. Pics on the rear of my intake below.
http://community.webshots.com/photo/...70683000Fbueyy
Jeff D
Old May 4, 2003 | 04:32 PM
You can completely remove the solenoid and plug the vacuum nipple in the middle of the manifold. Tie the solenoid electrical connector out of the way.
dfarr67
Apr 10, 2015 07:44 PM
edman
Mar 13, 2015 09:39 PM
97SSdude
Dec 31, 2014 07:43 PM
1994TransAm
Aug 31, 2002 09:33 PM
