Removing crank hub??
Old May 29, 2004 | 04:15 PM
  #16
TN94Z's Avatar
Thanks that idea worked...got my hub and timing cover off..can't find my torx bits or I would have the cam out. One bad thing though, I tore the seal at the bottom of the timing cover. I couldn't get the oil pan to drop down any and that was prying the crap out of it with a big screwdriver....it didn't tear completely but you can see that it is torn. I guess I will be replacing the oil pan gasket as bad as I hate to. I know that will probably be a PITA to do. But anyway thanks again.
Old May 30, 2004 | 12:25 AM
  #17
Smokn '94 Z's Avatar
Thumbs up
When you get ready to re-install the oil pan gasket, send me a shout. I have a easy way to fish that sucker on there without lowering the oil pan any lower than you have to...
Old May 30, 2004 | 08:57 AM
  #18
TN94Z's Avatar
Cool, thanks. I am gonna go ahead and get everything else installed and then do that last, but I will let you know. I want that to be as easy as it can be.
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
1LEThumper
Jul 14, 2003 12:45 PM
