removing cluster
Old Aug 7, 2005 | 06:10 PM
blackz151's Avatar
removing cluster
if i was to take out my cluster and get a fiberglass dash with all autometer gauges in it. will the car run or does it need to see somthing in the cluster? will there be any problems?
Old Aug 7, 2005 | 06:44 PM
Jameslt1TA's Avatar
Re: removing cluster
People have done it before...may be kind of expensive to run all auto meter. If something didn't work right im sure it could be worked out with lt1 edit or a mail order tune from madz28 or something.
Old Aug 7, 2005 | 07:31 PM
madwolf's Avatar
Your car will set a code for not having a service engine light. You could either wire one or you will need the code disabled through programming or else the fans will stay on all the time. Otherwise, you should have no problems.
Old Aug 7, 2005 | 10:37 PM
IrocSS85's Avatar
the hardest part is making the piece the gauges mount in. getting the gauges even, centered, and nice lookin. the rest is just a matter of figurein out which wires from the orig. gauge cluster go to what. Ive been thinkin of doi this myself since I have a full set of phantom gauges sitting here. Im goin to do mine in alum. if I do it.
Old Aug 7, 2005 | 10:42 PM
Jameslt1TA's Avatar
See i knew madz what have the answer.
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Boss002
Jan 20, 2016 12:17 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Jul 17, 2015 02:47 PM
ducttape1975
Jul 10, 2015 06:29 PM
