removing back seats
Old Sep 2, 2003 | 07:20 PM
z28marine's Avatar
removing back seats
has anyone removed their back seats? I never use them and hate when people sit back there. I want to remove them, but make it look really clean and nice. has anyone done this and have some pics?
Old Sep 2, 2003 | 07:24 PM
RamAir95TA's Avatar
They're pretty easy to remove; just a few star bolts. You will need to cut the seat belt plastic retainers to get the seatbelt out. With them removed, they don't look bad at all. You'll save around 17 pounds.
Old Sep 2, 2003 | 07:36 PM
revtime's Avatar
Yep easy to do.
You do want to remove the seats and the seatbelt hardware, I think it looks best like that.
You don,t have to cut anything up, at least I did not on my 94, just take the 2 screws out of the seatback that holds the belt guide and leave them on the belts, then remove the belts.
This way if you ever want to reinstall em you can.
Old Sep 2, 2003 | 11:37 PM
Kind of hard to see into the back, but you get the general idea:
Interior shot
Each seat bottom is held in by a single hex-head bolt. When you pull the seat bottom out, there will be a bare spot in the carpet, about 8" x 2" with the sheet metal showing through. I just leave the floor mats over that. The back is held in by a single Torx screw on the bottom/side of the seatback, through a tab attached to the side sheet metal.
I would also say to remove the belt completely... if you do that, you can get the weight savings up closer to 30#. When you pull the belts out of the floor, you need a T47 socket, but a T50 will work if you tap it in with a hammer. Get some small plastic "body plugs" to fill the holes with. The harness retractor is under the side plastic covers, and held in with a (I think) single nut. I made small plastic filler pieces to cover up the holes where the harness comes through the plastic panels.
filler piece in harness hole
Old Sep 3, 2003 | 01:43 AM
Twice The Fun's Avatar
not a great pic but a small idea....i havent made in fil cover and still leave the backseat pads in if neone needs to ride back there...it makes the rear look alot cleaner and "smooth flowing"
Old Sep 3, 2003 | 05:31 AM
Fastbird93's Avatar
Originally posted by Injuneer
I made small plastic filler pieces to cover up the holes where the harness comes through the plastic panels.[/URL]
How did you make that plastic piece, and would you maybe be willing to make and sell me a set?? Pretty please???
Old Sep 3, 2003 | 05:56 AM
revtime's Avatar
I would be interested in knowing how you make those as well, since my backseat aint never goin back in.
Old Sep 3, 2003 | 06:03 AM
ishz28's Avatar
If you seats are Charcoal on Gray in color, would you be interested in selling me the bottom cusions of your back seat??
Old Sep 3, 2003 | 06:12 AM
revtime's Avatar
Sorry man.
I have one of the very few 94 Zs with leather interior.
Not that I would not sell em to ya but I am guessing you have cloth.
Old Sep 3, 2003 | 03:16 PM
ishz28's Avatar
Yes indeed, I have cloth. Thanks for replying anyway.
Old Sep 3, 2003 | 04:30 PM
Get a thin sheet of fairly flexible plastic. Trace the opening on the plastic and cut the plasitc about 1/2" larger than the opening on each edge. Paint it with Eastwood Company "graphite" vinyl spray paint. Tape or glue the filler piece to the inside of the plastic cover.
I made my first set with carboard.... and it looked just as good.
Old Sep 3, 2003 | 07:42 PM
Fastbird93's Avatar
Coming from you I would have expected something a lot more technical, not just taking a piece of plastic, trimming it, painting it, and glueing it on............
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Snoman73
Nov 17, 2014 07:22 PM
ur2slo50
Sep 10, 2002 07:27 PM
nautilus
Aug 22, 2002 11:49 PM
firebirdude
Aug 7, 2002 07:31 AM
