Removing 3-4 shift fork...
Im not seeing how this 3-4 fork comes out... Is there a specific gear or way to pull it out with the syncro assembly? Yes, I did remove the snap ring.
I found two broken detent rings in it! One of the detent rings that was broken was where the tension ring clipped onto as well! Scary eh?
And why isnt there a tranny tech forum?
The guide for rebuilding it tears it apart a different way forking from the back to the front. I want to do it from the front to the back, which is how i heard it is supposed to be done.
Originally posted by 95 Z/28 LT1
Did you download the guide for rebuilding it?
stockssn2o
May 25, 2015 08:54 AM
Apr 16, 2015 09:57 AM
