removed the intake manifold...
Old Oct 8, 2003 | 07:24 PM
slverbullet's Avatar
...to replace the gasket. no problems as far as thats concerned. just wondering if while i have the manifold off, how should i clean it up. just wipe it all down or use some cleaner? also with the throttle body should i clean it up with throttle body cleaner? thanks.
dave
Old Oct 8, 2003 | 07:30 PM
Whistler's Avatar
While you've got it off you can hose it in Brakekleen... that should remove anything greasy.
Old Oct 9, 2003 | 06:47 AM
IDOXLR8's Avatar
I would recommend using a razor blade to remove any of the old gasket material. Then I would use any brake cleaner to remove any oil from the surface. I would recommend using SEAfoam to clean out your throttle body. Do not use brake cleaner to clean your TB out. You run the chance of removing the coating from the throttle blades.
Old Oct 9, 2003 | 10:24 AM
i387's Avatar
Is it normal for the lifter valley to smell horrible when you first take the intake manifold off?
I have 115K miles on the car, so I guess the burnt oil smell is to be expected, but when I took the manifold off I had to stand back! Pew!
Old Oct 9, 2003 | 10:51 AM
94formulabz's Avatar
What kind of coating is it? Can you offer anymore insight?
Old Oct 9, 2003 | 11:02 AM
IDOXLR8's Avatar
There is a form of anti-carbon coating on the throttle blades.
Old Oct 9, 2003 | 11:04 AM
IDOXLR8's Avatar
I remember my buddy was removing a manifold one day and the thing smelled like rotten eggs. It was horrible. I think this is normal with higher mileage cars.
Old Oct 9, 2003 | 11:15 AM
i imagine i can get sea foam at an auto parts store? also, i used the carb, choke and throttle body cleaner on it. that wouldnt have removed any coating would it? i wouldnt think so but i'm asking just in case. also, can i pick up that gasket thats under the throttle body plate at an auto store? thanks again guys.
Old Oct 9, 2003 | 11:23 AM
Pretty normal for it to smell. The more miles, usually the stinkier. A really dirty, sludged engine will really stink.
Change your rear end fluid. It will make you feel better about the smell of the engine.
Old Oct 9, 2003 | 11:48 AM
CoUnTryMuZiCZ28's Avatar
Yea, that rear end fluid smells bad.. Yikes!! gags me every time!!lol
Old Oct 9, 2003 | 07:06 PM
Kataklysm's Avatar
You guys don't like 80-90 in the morning? Come on, gear oil is great, especially when it overflows all over ya.
Old Oct 10, 2003 | 07:18 PM
Fast Caddie's Avatar
Had some new gears installed last week and went straight to the interstate for over an hour. Didn't want to do it, but had to and ended up overheating the rear end. Changed it out with new oil today. And the only thing that stinks worse than gear oil is overheated gear oil I'm talking a puke kind of stink.
Also fixed the intake leak last year and the lifter valley stunk too.
ModdedNerd
Jan 29, 2015 07:23 PM
rjc1629
Jan 27, 2015 10:46 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
