Removed Intake.......
Old Jul 2, 2005 | 10:47 PM
1quikZ's Avatar
on My next LT1 project motor and couldnt beleive what I found, The entire valley was filled with rocks leaves dirt and other debris However the motor was cleaner than anything Ive worked on before 0 sludge. I was shocked as Ive never seen this before. Any cause for it? Should I assume the bearing are screwed?
Old Jul 2, 2005 | 11:12 PM
Re: Removed Intake.......
Is this a joke? The only way debris like that could have gotten into the lifter valley is someone put it there (or the motor was left outside with intake off) and the intake was put back on. IMO, nothing else in the engine can be trusted.
Old Jul 2, 2005 | 11:21 PM
69vette's Avatar
well if it had all these rocks and dirt and debris then it could not have been run for very long with them in there if at all. I'm sure the motor would be trashed if this stuff was actually found in it.
Old Jul 3, 2005 | 12:06 AM
FastZinTennessee's Avatar
I changed the oil in my car once, and a leaf came out of the drain hole with the oil No rocks and debris though!
Old Jul 3, 2005 | 12:14 AM
1quikZ's Avatar
I cannot figure out how the hell it would have got in there, The motor has 67000 on it out of a 95 caprice, everything was sealed up tight original gaskets, and I heard it run before i bought it? I thought maybe it had no air filter, but then would that stuff get in by the lifters?????
Old Jul 3, 2005 | 12:44 AM
Mean Green Z28's Avatar
I've seen crazy shyt like that before too. We once took apart a SBC and there was a nest inside the intake. This engine had the air filter on it too but sat for a while. It was all cotton and other crap like a mouse cage. We were like WTF??? All we could think of was that they got in there though the exhaust port and throught the valves.
Old Jul 3, 2005 | 07:01 AM
slopokrodrigez's Avatar
Yeah but that's in the intake. He said it was in the LIFTER VALLEY.
My money is on you not getting the same motor you heard run. They cleaned up another motor that was sitting around before you came back to pick it up. I bet they didn't give you a warranty of any kind either.
Old Jul 3, 2005 | 11:13 AM
1quikZ's Avatar
nope same motor, but i found the problem, intake is split at the back, didnt see it last night it was dark, you can look through the split right into the valley......I figured there must be something wrong with it I only payed $500
greenzee28
Sep 25, 2015 04:29 PM
Jake Bialke
Sep 24, 2015 11:31 AM
wbspoon
Sep 19, 2015 08:12 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
