remove valve covers.
Old Jul 17, 2007 | 07:32 PM
ROUDA's Avatar
do you have to replace the valve cover gasket if I remove it Im haven trouble getting a the header on the passeger side through the botton so I will try the top but the valve cover is in the way.
The driver side needs to be hit to notch out room for the steering does that sound comon.. There pacesetter longtubes
Old Jul 17, 2007 | 07:50 PM
LSWHO's Avatar
I believe it is recommended. I would to keep them from leaking oil everywhere.
Old Jul 17, 2007 | 07:51 PM
josievers's Avatar
You shouldn't have to replace it if it is newer. I installed a new set five years ago and just removed my valve covers the other day. They were like new yet!
Old Jul 17, 2007 | 07:53 PM
ricehammer's Avatar
Its recommended, but I've pulled my valve covers several times and not replaced the gaskets. If you are using cork gaskets then definitely replace them. If they're rubber, chances are you'll be ok.
Old Jul 17, 2007 | 07:57 PM
2000GTP's Avatar
I've removed the valve covers several times with the factory rubber gaskets and haven't had any issues with oil leakage.
Old Jul 17, 2007 | 08:00 PM
SS RRR's Avatar
As long as the gaskets are not cracked or hardened then they are fine. I think those type of gaskets will actually outlast an engine.
Old Jul 17, 2007 | 09:29 PM
ROUDA's Avatar
they look ok and I good the header in place. thanks.
Apr 3, 2015 10:54 AM
lt1matt
Mar 21, 2015 07:35 PM
ModdedNerd
Jan 29, 2015 07:23 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
