Remove timing chain cover = dropping the oil pan?
Old Sep 11, 2005 | 10:17 PM
  #16
Warlock1313's Avatar
Re: Remove timing chain cover = dropping the oil pan?
doesnt look like its a tooth off , wasnt there some post about the opti being a tooth(?) off and causing problems.
Old Sep 11, 2005 | 10:34 PM
  #17
snakethis69's Avatar
yes if the opti is off it will run like w****, mine did at least
Old Sep 11, 2005 | 11:03 PM
  #18
Originally Posted by Z95m6
i can't believe you guys think its off a tooth. I'd almost bet money that thing is right. The crank looks a little farther off than the cam but the crank turns twice as fast as the cam so when you move them back to line them up they should hit at the same time.
Without a better pic, there is no way to tell for sure. I am not going to tell someone it looks ok, if I can't tell it really is.
Old Sep 11, 2005 | 11:04 PM
  #19
Z95m6's Avatar
Thats true, but i'm sure not gonna tell him its off one tooth either as it isn't that obvious. I'd hate to tear into my motor if its not off one tooth, although the front cover isn't that hard to do. I guess thats probably a sign i've had my car apart to many times.
Old Sep 11, 2005 | 11:10 PM
  #20
ZMAN Z28's Avatar
I'm in college right now to be a laser tecnician, and my first year was all electricity. Electricity does some weird things when not grounded properly. It can and will change voltage quite a bit. If you are driving and the ground isn't making a clean connection, it can cause the electronics and sensor to act differently and the compuer would probably try to act accordingly. I'm not saying it is your problem, but it doesn't hurt to go back and re check grounds especially after a rebuild.
ZMAN
Old Sep 11, 2005 | 11:17 PM
  #21
ZMAN Z28's Avatar
Also another thing to check is your plugs again. Even though you put in fresh plugs, maybee one cracked the porcelin. You might want to look under the hood in darkness to see if there is any arcing. You can also take a spray bottle with water and spray it on each header to see if you have any cold cylinders. Those are a couple of ways to see if all of your cylinders are firing correctly. They aren't 100% for sure, but its the easy stuff to rule out first. It's too close to tell in your picture about the sprocket alignments.
ZMAN
Old Sep 12, 2005 | 12:39 AM
  #22
Evil Eric's Avatar
ditto.
you sure you have your plug wires on straight?
Old Sep 12, 2005 | 12:49 AM
  #23
Silvershark's Avatar
I ran 15.21 at 94.7mph. 1/4 mile. I am thinking my timing chain my be off as well....
Here is a picture of my double roller install...
http://www.akgaming.com/~kendall/images/100_0019.jpg/
Old Sep 12, 2005 | 12:56 AM
  #24
Z95m6's Avatar
Your link doesn't work.
Old Sep 12, 2005 | 01:05 AM
  #25
That dang site is always down... time for a new host... It works, just off and on. I can email that to you as well...
Old Sep 12, 2005 | 01:07 AM
  #26
simple's Avatar
you had an extra "/" at the end of the link
yours looks fine with the dowel at 3, the cam at 6 and crank at 12
EDIT; and you didnt have too install a freeze plug where the waterpump drive shaft fit thru the block
Old Sep 12, 2005 | 01:08 AM
  #27
Z95m6's Avatar
i'm no pro but i'll take a look at it. I'll also pass it on to my friend who knows a lot more about it. Send it to cj428mach@yahoo.com
Old Sep 12, 2005 | 01:11 AM
  #28
simple's Avatar
look at post #26, no need too e-mail it, it works
on topic, i didnt drop the pan at all too remove or install the timing cover
on the inside of the timing cover is a lip that the front gasket seats into. when you pull the timing cover off. you will see that the lip has pointed edges on each side...you can cut/grind those "ears" off the timing cover for an easier install without dropping the pan
dont take too much away tho as you can go too far and cause an oil leak. only about a 1/4" needs taken off each side
Old Sep 12, 2005 | 01:26 AM
  #29
Z95m6's Avatar
We are talking about his datalog.
Old Sep 12, 2005 | 01:27 AM
  #30
simple's Avatar
i knew that
