Remove Speed Limiter?
Old Dec 5, 2004 | 05:20 PM
  #16
Zepher's Avatar
Re: Remove Speed Limiter?
Originally Posted by Bryan Smith
You really dont get it programmed out, you can just reset it to a speed no fbody has gotten to yet. 255mph. I had mine reset while doing other things in the pcm.
There are plenty of f-body's that exceed 255mph.
There is a 92 Firebird that hits 307mph every now and then.
Old Dec 5, 2004 | 05:49 PM
  #17
Bryan Smith's Avatar
Really.. man im so outdated.
Old Dec 5, 2004 | 08:44 PM
  #18
350jeep's Avatar
My '94 six speed LT1 has the ~110 speed limiter and the 110mph speedometer that the 6 cyl. camaros have. I checked the VIN and all other codes and confirmed its an original LT1. Is this odd? I thought LT1's had the 155mph speedometer and ~155 speed limiter. The only thing I can think of is that is was built in Canada. Any thoughts?
Old Dec 5, 2004 | 08:47 PM
  #19
mustangmuncher's Avatar
Is your car a vert? I know LT1 vert's that didn't have the Z rated tires factory (i think that was the option?) have 110 speedometer/limiter.. I have seen one, it was a 94 black M6 vert.
  #20
ZeeDub's Avatar
Originally Posted by Mtrhds94Z
Also,.. "? 93 is a 4th gen, to my knowledge they still use the OBDII connector with the OBDI computer" is not correct..
Only 95's have 'OBDI with OBDII connector'.. 94 is OBDI with OBDI connector..and 96-7 are OBDII..[with OBDII connector]
i know a few people with OBD 2 connectors on a 94...
Old Dec 5, 2004 | 08:49 PM
  #21
madwolf's Avatar
The only 94 which got a FACTORY OBDII connector were the Corvettes. No 94 F-bodies had an OBDII connector.
Old Dec 5, 2004 | 08:50 PM
  #22
ZeeDub's Avatar
tell that to my boy andre...
Old Dec 5, 2004 | 08:59 PM
  #23
Zepher's Avatar
did he buy the car new or used?
It's not too hard to change the connector.
My 86 Trans Am has an OBDII connector in it.
Old Dec 5, 2004 | 09:00 PM
  #24
350jeep's Avatar
No, my car is a coupe, original tires are the P235/55R16. Its very strange.
Old Dec 5, 2004 | 09:04 PM
  #25
Zepher's Avatar
I beleive those are the non z-rated tires. I've seen a 93 Z and a 94 like yours with the 110 speedo as well. Both came standard with non-Z-rated tires.
I think the 93 had yellow numbers too. can't remember the 94 though.
Old Dec 5, 2004 | 09:10 PM
  #26
350jeep's Avatar
hmmmmm, interesting. But, i'm pretty sure only the '93's had the yellow numbers, mine doesnt.
Old Dec 5, 2004 | 09:33 PM
  #27
AMXGUITAR's Avatar
My 94 has a 110 speedo. i dont remember if it had Z rated tires or not on it. If i put a 155 speedo in it does that need to be programmed (or changed) in the comp too? cause my girlfriend's neon has a speedo that goes higher than mine and its stock. Thats embarassing...
Old Dec 5, 2004 | 09:35 PM
  #28
madwolf's Avatar
No changes necessary when upgrading to a 150 speedo. If you currently have a speed limiter then you might want to have that programmed out, but you will be ok other than that.
Old Dec 5, 2004 | 09:56 PM
  #29
I can vouch for that.
My 94 Formula LT1 had the 115 speedo 108 speed limiter. Swaping clusters is no big deal. Plug and play.
Old Dec 5, 2004 | 10:09 PM
  #30
My94T/A's Avatar
I have a 94T/A coupe with T-Tops that has a 110mph speedo. I been having a hard time looking for a cluster. Do you guys know anyone or anyplace that I can pick one up for cheap...
