removal of the hub on the crank infront of the front timing gear?
can i just use a puller to remove the 3 sided hub that is on the crank but behind the timing cover? we are putting the motor from a 95 into a 97 and the 95 didnt have this pickup hub on it.
Hard to tell....
It's "infront of the front timing gear", "but behind the timing cover." Sure sounds like the reluctor gear to me.
Let's try this, using Shoebox's stuff:
Is it part #45?
... or does it look like a flat disc with 4 lobes?
Is it part #45?
alright listen, alot of people ask this question.
listen to me lol i spent 2 ENTIRE days trying to get mine off, i almost resorted to pulling the motor.i used everything from hammers to torches to every puller i could find so listen close.
go to autozone,
rent the puller made by chrystler(sp)
i used many others, bent grade 8 bolts and stripped threads etc. use that one, it will come off no problem and use the longer of the 2 rods you get in the kit, youll understand what i mean when u look at it.
good luck
go to autozone,
good luck
I think he's talking about the reluctor wheel. Is the computer going to be OBD2 or OBD1? If you are sticking with OBD2 then make sure you have the correct timing cover and crank key as well. It should just pull off with little effort, may need a screwdriver to pry a little bit but not much. If going OBD1 then you still need it as a spacer to use the shorter hub, unless you have a OBD1 hub. All this of course is assuming your 95 motor is OBD1.
it was the reluctor ring, thank you guys for the help! i just took a big screw driver wrapped in a rag and tapped down betwoon the ring and the gear and it came right apart! no i need to swap out the keys as i am OBDII and the motor we are using is OBDI
it has 3 sides and sits infront of the crank shaft timing gear.
