relocation brackets required for aftermarket LCAs? or just better to have?
Old Aug 12, 2003 | 08:35 PM
Robert95z's Avatar
question in the title... Will i need to buy relocation brackets to fit aftermarket LCAs? My car isnt lowered so would they still benifit with LCAs?
And will LCAs do anything without the relocation brackets?
Old Aug 12, 2003 | 09:09 PM
LPEdave's Avatar
Getting LCA's is unrelated to getting LCA drop brackets. If you lower the car, you probably want the brackets, so you can adjust the LCA's back to level, or heading uphill if you're drag racing.
A good rod/poly or rod/rod LCA will help on the road course or drag strip.
Dave
Old Aug 12, 2003 | 09:10 PM
Geezer powered's Avatar
lpe is correct
Old Aug 12, 2003 | 09:11 PM
Robert95z's Avatar
oh ok, and would i want poly bushings or poly/rubber bushing?
Thanks,
Robert
Old Aug 12, 2003 | 09:33 PM
LPEdave's Avatar
It kind of depends what you're trying to do with the car. If it's a street car and you just want to stiffen it up a bit, get poly/rubber. If you're drag racing exclusively, poly/poly might be best. If you're autocrossing or road racing, then poly/rod end, or two rod ends is the way to go.
Dave
94B&RZ-28
Dec 22, 2008 10:00 AM
Espo
Aug 22, 2002 06:57 PM
96z
Aug 17, 2002 09:29 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
