Relay For electric water pump??
Old Jan 30, 2005 | 11:24 PM
"White Knight"'s Avatar
What relay should i use with my electric water pump and where should i get it? I have heard or Barry Grant Relays, but have no idea where to get them.
Old Jan 30, 2005 | 11:39 PM
Birdman7389's Avatar
Re: Relay For electric water pump??
Just a regular 12V relay you can get from autozone or any of the parts stores....
Old Jan 30, 2005 | 11:51 PM
turbo_Z's Avatar
I got a fog light relay from autozone.
Old Jan 31, 2005 | 12:44 AM
CCCCCYA's Avatar
Any 30 amp DPDT relay you can source will work just fine. I know the pump doesn't PULL 30 amps, but you don't want to undersize a relay. It heats up in use if it's too small. Just get a 30A and have at it
Dave C.
Old Jan 31, 2005 | 02:13 PM
What does "DPDT" mean?
Thanks for the info guys
Old Jan 31, 2005 | 02:50 PM
DPDT= Double Pole Double Throw
Old Jan 31, 2005 | 03:06 PM
Double Pole Double Throw, but I don't know why you should need one. Maybe CCCCCYA can explain. Pretty sure most automotive relays are single pole.
Old Jan 31, 2005 | 05:21 PM
LT4orbust's Avatar
using a dpdt relay allows you to run the power and ground through the relay, all you need imo is a spst relay , i would just run the power wire through the relay, and ground to the engine or battery neg.
if you already have a dpdt relay...you can still use only one of the sets of the contacts , if they burn out ...switch to the other set
Old Jan 31, 2005 | 06:17 PM
CCCCCYA's Avatar
I like the DPDT for reasons of wanting to source an indicator light from same input line as the actual device, but not on the physical line to the pump. I don't like splices, and the DPDT lets me wire it a little cleaner. It's all personal preference though, as you are absolutely right. You don't need a DPDT, all you need is an SPST. They are indeed a lot easier to find than DPDT relays, and cheaper to boot.
Dave C.
Old Jan 31, 2005 | 06:24 PM
LT4orbust's Avatar
Dave C.
very good idea , the indicator light,
Old Feb 1, 2005 | 07:08 AM
That is a good idea. I don't like to splice wires either. So where is your indicator light located at? That's a pretty good idea.
Old Feb 1, 2005 | 07:29 AM
Dave C.
If you use a pole of the relay for a light, isn't it just going to tell you that the relay has operated and not the the pump is actually running?
Old Feb 1, 2005 | 08:01 AM
teke184's Avatar
painless wiring - water pump relay
kindda $$ compared to a DIY relay setup, but at least you know it will work well and look acceptable.
Old Feb 1, 2005 | 03:46 PM
^That looks pretty good, a little pricey like you said, but i just might go for it.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Stay Puft
Apr 20, 2015 06:24 PM
Queens94z28
Dec 20, 2014 09:11 PM
Zone
Jul 29, 2002 07:43 PM
