Relay for elec. waterpump
i got this red led from the shack, its wired up so that it lights up when the pump is on, the light already had a resistor and wasnt too bright, so it will be ok at night. 2bucks, rip off tho, but necesecary.
i got my 12volt 30amp relay from my local parts store "westminster autoparts" 8something bucks
A good relay to use is the same as the one for your fog lights in the relay/fuse box under the hood. That way, you can get one at any auto parts store should it fail. I used standard spade terminals on my wiring, so I can swap out the relay in a few seconds.
BRAD
BRAD
Aaront810
Aug 29, 2020 09:34 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
