relay
Old Jun 21, 2013 | 07:17 PM
Shangrila's Avatar
relay
Which relay do you use when converting from a z28 rear deck lid spoiler to a SS style wing? I saw Shoeboxs site but it had no part #.
Old Jun 21, 2013 | 09:02 PM
Re: relay
Any +12v automotive relay.
Old Jun 23, 2013 | 07:21 PM
Shangrila's Avatar
Re: relay
Tnx.
Old Jun 24, 2013 | 05:49 PM
Shangrila's Avatar
Re: relay
So it didn't work, I hooked up the relay 85 and 86 in series with the yellow wire on 85 and the red LED wire on the 86 as the diagram showed and the ABS light was still on. If it's resistance I'm looking for then can't I just us a resistor in line?
Old Jun 24, 2013 | 09:24 PM
Re: relay
The purpose of using the relay is because a normal resistor cannot handle the load and will fry. Are you sure you wired it right? Are you saying your wires are yellow and red and not yellow and black (or red and black)? I'm pretty sure it has worked for other folks.
Old Jun 25, 2013 | 07:26 AM
Shangrila's Avatar
Re: relay
The wires from the factory harness is yellow and black, the aftermarket ss wing wires are red and black. I took yellow and put it on #85 then took red from ss wing and put that on # 86. Basically the power supply is in series with the relay.
Old Jun 25, 2013 | 07:32 AM
timnfxr's Avatar
Re: relay
Rob:
From the posts I've read on several forums, the relay mod (wired as indicated) worked fine.
Old Jun 25, 2013 | 07:47 AM
Re: relay
Well, that is not what the diagram shows. It goes between the black and the red (or yellow). Try wiring it that way and see what it does.
Old Jun 25, 2013 | 09:27 AM
Shangrila's Avatar
Re: relay
Guess its a parallel circuit, I'll mess with it more tonight when I get home Ty
Aaront810
Aug 29, 2020 09:34 PM
OutlawPerforman
Oct 30, 2017 05:40 PM
Jeff1904
Jun 5, 2016 05:00 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
jerrysims71
Aug 15, 2015 12:47 PM
