reinstalling lifters
Old Jan 19, 2006 | 02:07 AM
formula69's Avatar
is it bad if you dont keep your lifters in the order they came out? i kinda just took mine out and threw them in a bag..
Old Jan 19, 2006 | 02:16 AM
Wckd94Z's Avatar
Re: reinstalling lifters
i dont' think it's bad bad. but if you try to put the lifters in the "wrong" hole they might fit a little too tight. I labeled mine, went back in real smooth...
Old Jan 19, 2006 | 02:33 AM
formula69's Avatar
blahh i think im just going to get new stock replacements... know anyone that is reliable?
Old Jan 19, 2006 | 10:17 AM
OBE1 95Z28's Avatar
If your lifters don't have high mileage, not sure itf there's a lot of benefit to replace them. Ideally you'd put the same lifter back in the same hole to keep the wear patterns lined up. Replacing them with new ones will also create a new wear pattern. The fact that they're roller lifters reduces the wear pattern "mating" compared to a flat tappet design.
Old Jan 19, 2006 | 11:28 AM
formula69's Avatar
well the car is getting a new cam.. probably gm 847 and i DONT want to risk lifter failure at 6800 rpms.. i have no idea which hole each lifter is supposed to go into so ill probably just fork over the cash for some good stock replacements unless someone can give me an excellent reason to stick with what i have.. the car has 93k miles on it but i have no idea how many miles are on the lifters
OutlawPerforman
Oct 30, 2017 05:40 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
