Reg. or Premium gas??
Old May 22, 2004 | 10:51 PM
brians96Z's Avatar
What are all you guys running? From what I read, the LT1 only calls for 87. Is that true? With gas prices here in Ohio over 2.00 for 87, the premium is getting a little ridiculous. I know some of you are gonna disagree with me on this, but I have NEVER noticed a power increase by using Premium fuel. The only thing I have seen that it helps is pinging. So as of late I try to run 89. let me know what you all run.
Old May 22, 2004 | 10:52 PM
Z28WannaB's Avatar
Well I suppose you can run regular, but if you hear any knock you should turn it off immediately and get some higher octane in there.
Many people on here have highly modded LT1s so most likely they run premium.
- Z28WannaB
Bobs 94 TA's Avatar
I only run 93.
Old May 22, 2004 | 10:53 PM
Eliminator's Avatar
Originally posted by Bobs 94 TA
I only run 93.
Same here.
Old May 22, 2004 | 11:01 PM
JB'z 94's Avatar
I run 91, because in CA we can't get 93... and its about $2.40 a gallon for 91 right now in town.
Old May 22, 2004 | 11:45 PM
ibanez6rg's Avatar
Re: Reg. or Premium gas??
False. Read the inside of your gas cap.
I run 93+ only.
Old May 22, 2004 | 11:54 PM
camarokid24's Avatar
Last time I looked in my car manual it said 91 octane or higher. I have used 87 before though, you can but gm dosent recomend it
Old May 23, 2004 | 12:00 AM
Eliminator's Avatar
With todays gas prices I am glad mine isnt a everyday driver.
Old May 23, 2004 | 12:07 AM
Bobs 94 TA's Avatar
Mine is.
Old May 23, 2004 | 12:11 AM
screamin94Z's Avatar
Mine is.
mine too and premium is 2.17 right now here. hate it but i wont give it up.
Old May 23, 2004 | 12:16 AM
Bobs 94 TA's Avatar
It's 2.29 here. My sister is leaving for school next month(), and I'll have her car to drive while she's gone, so I'll be able to pump 87 now.
Old May 23, 2004 | 08:43 AM
Dave Feerst's Avatar
you wont get full spark advance on 87 or 89, in case of emergency you could run it, but I wouldnt reccomend it. spark knock will destroy a motor.
Old May 23, 2004 | 09:57 AM
brians96Z's Avatar
Well, I think I'll just cut out the 87 all together, and stick with 93 or Al least 89. (When the 93 is too high)
Old May 23, 2004 | 10:10 AM
KnightRider2000's Avatar
Definitely go with 93 when you have a chance...
anything less and you will have problems IMO
Old May 23, 2004 | 10:17 AM
pearlpurple's Avatar
Up in Northern Ontario all I can get is 91 which is about $1 per Liter,,,,,, not per gallon!!!!!! That translates into about $3.75/gallon
Oh well live with I guess,,,,,,
What about octane boost additives, if it says it will raise the octane by say three points is that from 87 to 90 or 87 to 87.3???
Right now it is not economical to use octane boost but it may become so.
