Red Line VS Royal Purple.
Old Sep 14, 2003 | 12:33 AM
Cerwin Vega Fan's Avatar
Question Red Line VS Royal Purple.
Would you put any of these two in your car and if so which brand would you use?
Thanks,
Chris
Old Sep 14, 2003 | 12:57 AM
scoobysnax83's Avatar
Mobil 1 Synthetic.... O wait that wasn't a choice
I'd go Redline. What a way to start a midnight flame war...
Old Sep 14, 2003 | 12:59 AM
Well the third option does mean you pick some thing else.
Old Sep 14, 2003 | 01:24 AM
Re: Red Line VS Royal Purple.
Thanks,
Chris
so would you word it, "Would you put any of these two in your car and if (NOT) which brand would you use?"
That would be better....
Old Sep 14, 2003 | 01:39 AM
pasmado15's Avatar
I've had a limited exposure to Red Line. After the break in period this Z28 has only used Red Line products -- currently at 222,587 miles.
Still strong during acceleration (still can whip lash passengers' necks - hehehe) and with only a slight trace of carbon film at the exhaust tips.
quality products
Old Sep 14, 2003 | 01:45 AM
chasmanz28's Avatar
ditto mobil 1 syn
Old Sep 14, 2003 | 03:01 AM
5.0THIS's Avatar
I currently use M1, but both RP and Redline are quality products. I have used redline also in my racecar trannies and rear axles and it has worked well.
Old Sep 14, 2003 | 03:49 AM
CoUnTryMuZiCZ28's Avatar
um i dont want to sound dumb but i think he is talking about radiator additives.. royal purple is famous for there radiator additives.... I wouldnt use redline.. i used it for about 3 weeks and i blew 2 hoses.. royal purple i havnt tried.. i use a stuff called TOWKOOL.. works great so far i have had it in 5 months and no problems. about to drain everything though.. getting ready for head port..
Old Sep 14, 2003 | 04:27 AM
Patman's Avatar
Without a doubt, Redline is better. It's definitely one of the top three oils you can buy. This oil is very stable, unlike Royal Purple which thins out far too easily. Some of the lowest wear numbers I've ever seen in oil analysis have come from engines running Redline.
Redline uses a polyol ester base oil, which helps clean engines very well, as well as they've added a good dose of moly too, which is a good antiwear additive.
Amsoil is also very close in quality to Redline, almost too close to call actually. But Royal Purple is not even in the same league as these guys. Mobil 1 is merely ok, but is still better than RP. I think Mobil 1's 5w30/10w30 is too thin for the LT1, if you use M1 go with their 0w40. Redline and Amsoil 5w30 are almost 5w40s.
Old Sep 14, 2003 | 04:36 AM
You're the one that did the huge post a while back on the oil analysis, right? That was pretty informative. Could you provide a link to it if its still around somewhere? Its probably lost in neverland by now, but who knows....
Old Sep 14, 2003 | 04:37 AM
http://www.bobistheoilguy.com/images/lucas/lucas.htm
Old Sep 14, 2003 | 04:38 AM
Good post, thats another good one that I forgot about....
Old Sep 14, 2003 | 04:40 AM
go to the main page and it tells you every thing about oil.. Thats the only link i had saved so i put that one for the lucas... theres much more
Old Sep 14, 2003 | 05:33 AM
Patman's Avatar
On the BOBISTHEOILGUY.com message board, you'll see all kinds of oil analysis reports posted, with many different cars and many different oils.
I'd love to see more of you LT1 guys doing oil analysis, so I'd have results to compare mine to. The more of you that do oil analysis the better, as we can then all learn from others as to which oils tend to show the better results. This is truly the best way to pick the right oil for your car, as oil analysis tells you exactly what is going on in there.
Old Sep 14, 2003 | 09:32 AM
S.J.S.'s Avatar
okay stupid question is Redline oil a synthetic oil?
