Red hot headers ? Rich or lean ??
Old Dec 29, 2004 | 10:29 PM
NOMAD's Avatar
I've seen so many threads about this lately, I figure I would post part of a article by none other than Smokey Yunick. Smokey is replying to a reader who has red hot headers on his circle track car.
"Red hot exhaust headers indicate a lot of heat an unburned fuel is being dumped out of the engine. It sounds liek your exhaust system is in the ball park. But check the back pressure at the highest RPM. A little bit bigger pipes won't hurt. Even well tuned engines will turn exhaust headers yellow hot. You've got 400-500 Cubic Feet per Minute at 1450 degrees F coming out of one 2.5" hole on each side. The exhaust temperature is usually determined by the efficiency of the combustion chamber including the piston shape. The ignition advance and air/fuel ratio will also influence the temperature. but the exhaust valve timing can really heat it up if you open the exhaust too quick and close it too late, you really dump heat out and lose horsepower. Most time when excessive header temperature is a problem, the camshaft is the cause.You might have a low battery or poor egine ground. If the ignition goes to hell you can be running into intermittent pre-ignition that can run cylinder temperatures an extra 300 degrees F really quick"
Hopefully this slings some light on the situation
-Shannon
Old Dec 29, 2004 | 11:00 PM
Re: Red hot headers ? Rich or lean ??
Someone is going to ask "who is Smokey Yunick?".
Old Dec 30, 2004 | 12:00 AM
ChevyTuffD.A.'s Avatar
Well.........who is he??
Old Dec 30, 2004 | 01:26 AM
CCCCCYA's Avatar
I hope your kidding...
Lets put it this way. Smokey Yunick was (still is to some degree with everything we enjoy because of him) to the Chevrolet V8 what Einstein was to physics. His contribution was THAT great. Man, talk about thinking "outside the box"! Hell, he thought OUTSIDE THE CAR in Daytona one time! (the alternator with a propeller thing..).
Do a google search and prepare to read for next year or so of your life..
Dave C.
Old Dec 30, 2004 | 03:00 AM
MentalCaseOne's Avatar
Lean!!!!!!!!!! Dog Nabbit!!!
No wait!! Clogged Cats!!!! Gawd Dang it!!!
No Wait!! Rich and burnt Valves!!!!! woulndt that have a popping sound??
Whatever man... I give up....
I am not gunna ask whose Smokey!! I just did =X
Marvin
Old Dec 30, 2004 | 08:49 PM
NOMAD's Avatar
Yep, Smokey was a great innovator. His reverse rotation engines and wild setups were fabled. the story of his running a pushrod engine at Indy a few years is amazing. He is a great story teller to beat all
-Shannon
Old Dec 30, 2004 | 09:54 PM
Mtrhds94Z's Avatar
Shannon
Please reply to my email or PM about whether you got my PMO and sent the item out yet..
Charlie
DirtyDaveW
Dec 1, 2016 05:37 PM
grabbem88
Apr 16, 2015 06:57 PM
Collector Car
Dec 17, 2014 01:12 PM
