recomendation on building up lt1 motor to place in 69 corvette
Old Feb 7, 2010 | 06:44 PM
lazboytt's Avatar
I just did an engine swap in my 96 camaro.
Im going to build the motor up and put it in my 69 corvette.
The motor spun a rod baring and a lob on the cam is bad.
Anyone have any recomendations on what is a good combination for this motor to turn it into a muscle motor.
The 69 corvette is a manual transmission. Someone took the original 427 out and replaced with a stock 350.
Im going to use the lt1 motor which i have the aluminum heads and build it up and switch to carbotated for the vette.
Obviously the motor needs to be bored out needs a new cam and the crank will need to be turned.
I prefer to order everything from summit racing since they have good pricing.
Anyone have any sugestions on what to place in the motor?
The car will not be raced. I dont want to loose my lo end tork since its not being raced.
Any recomendations would be greately appreciated.
Old Feb 7, 2010 | 07:14 PM
doferrell's Avatar
check out the build sheets from golenengineservice.com. they have 383 and 396 lt1 that range from 350 to 550hp and they all have build sheets that u can look at. also u can check out lloyd elliot and advanceinduction have good cam/head combinations for any type of build u wanna do.
Old Feb 7, 2010 | 08:13 PM
JoeliusZ28's Avatar
do you want it to go fast or not?
the stock setup is good for making torque if you just want to do a rebuild.
Old Feb 7, 2010 | 09:04 PM
lazboytt's Avatar
yes I want this to go fast. I would like to try and get 800 hp if possible with this block
Old Feb 8, 2010 | 07:30 AM
lt1-xjs's Avatar
I would be looking for an "original" '69 427 engine.
Old Feb 8, 2010 | 11:22 AM
Big boost or big nitrous.... what is your preference. And would that be 800HP at the flywheel, or 800HP at the rear wheels?
Old Feb 8, 2010 | 12:46 PM
ayers1967's Avatar
A 1969 vette drivetrain is not going to like 800 hp .
Old Feb 8, 2010 | 07:54 PM
lazboytt's Avatar
im not stuck on the 800, just figured it would be nice. I cant afford to buy a used 427 which is very hard to come by and then sink money into rebuilding it.
So since I have the lt1 snd aluminum heads at least it will save some money.
I am looking for something with power and sound something that will be noticed. I dont plan on racing the car.
I would like to turn it into a a true muscle car.
im not stuck on anything i would like to use the block and bore it out 30 over and have the heads re done. When it comes to the cam lifters lift duration i am lost.
I would even look at puting a different crank in if need be since i dont know if the stock crank would even be any good for this concept.
im open to sugestions.
Old Feb 8, 2010 | 08:24 PM
Air-Adam's Avatar
454 used the same block and head castings (though there are a few) as the 427. They are everywhere, and in the end, I bet you'd be money and time ahead to put a BBC into that car over the LTx. I've gone over this kinda stuff a few times helping my boss build his '69. Between the 350 it had, a BBC, and a 6.0LSx, the best route over all turned out to be the BBC. All the parts are readily available, its an easy swap because it was factory-equipped that way, and no electronics to nickel-and-dime the project to death.
I vote BBC.
Feffman
Oct 9, 2015 05:42 AM
Moshbmx1
Jan 20, 2015 03:27 PM
Collector Car
Jan 5, 2015 10:58 AM
Bearmans
Dec 3, 2014 05:28 AM
