Rebuilding LT1- LT4 hotcam 383
Old Jun 26, 2007 | 12:21 AM
NewbieWar's Avatar
ive got her in the shop and he says the crank is burnt and the heads were destroyed on the last rebuild... before i got the car...
i'm doing an entire engine rebuild... what if anything should i insure are included in my major overhaul
keep in mind... this car will probably never see a race track or a strip...
my trucks my daily driver but once shes out of the shop... i'm sure she'll share the load
Old Jun 26, 2007 | 12:23 AM
Javier97Z28's Avatar
Moderator
If you're gonna stick a hotcam in it, just go with a 355.
If you want something a little more fun, but relatively mild, stick an LE1 package on top of the 355.
Old Jun 26, 2007 | 05:24 PM
2000GTP's Avatar
If you were going to go through the effort to have a 383 put together, I would probably throw a little more of a cam in it then the Hotcam.
Old Jun 26, 2007 | 08:02 PM
my94blackz's Avatar
Dont run a hotcam.
Old Nov 18, 2007 | 01:02 AM
sn8ke eatr's Avatar
yea the hotcam pretty much sucks. my vote would be to do a 355 with the le1 package. it will make good power ( 370-390hp) and still be pretty streetable but will have way more power then a hot cam 383. the website is eportworks.com and the guys name is loyd. he should be able to help you out. good luc
Old Nov 19, 2007 | 04:25 PM
WS Sick's Avatar
If the motor needs redone anyway, build a 383 with heads and cam. a mild cam in a 383 with decent heads will build a torque monster that keeps you planted in your seat from the slightest tip of the throttle.
zFrank
Aug 12, 2015 03:46 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
1995Blackz28
Jul 20, 2015 09:34 AM
k1996z28
Apr 13, 2015 06:54 PM
