Rebuilding LT1- LT4 hotcam 383
ive got her in the shop and he says the crank is burnt and the heads were destroyed on the last rebuild... before i got the car...
i'm doing an entire engine rebuild... what if anything should i insure are included in my major overhaul
keep in mind... this car will probably never see a race track or a strip...
my trucks my daily driver but once shes out of the shop... i'm sure she'll share the load
yea the hotcam pretty much sucks. my vote would be to do a 355 with the le1 package. it will make good power ( 370-390hp) and still be pretty streetable but will have way more power then a hot cam 383. the website is eportworks.com and the guys name is loyd. he should be able to help you out. good luc
If the motor needs redone anyway, build a 383 with heads and cam. a mild cam in a 383 with decent heads will build a torque monster that keeps you planted in your seat from the slightest tip of the throttle.
zFrank
Aug 12, 2015 03:46 AM
