Rebuild or Replace??
Old Aug 30, 2013 | 03:55 PM
PurpSqad504's Avatar
I have a lt1 with 115,000 miles on it, in a Z28... I was told that I need a crankshaft kit to stop the engine from making a grinding type of noise when I start it up. I'm wondering should I do a rebuild with the crankshaft kit or simply purchase another lt1. Keep in mind, that I am a college student and looking to spend $2500.00 max. I need some opinions on cranks, piston, and etc also... Thanks to everyone, any information would be helpful.
Old Aug 30, 2013 | 04:24 PM
pizzi-man's Avatar
Re: Rebuild or Replace??
I don't know about needing a crankshaft kit because of grinding during start up. Hows your oil pressure and are you leaking oil out of the rear seal? How does it sound when it is running, any knocking noise?
Old Aug 30, 2013 | 04:42 PM
Yes it makes a knocking noise, and the oil pressure seems to be fine... I'm not sure if its leaking from the seal or not.
Old Aug 31, 2013 | 06:29 PM
pizzi-man's Avatar
Standard or automatic transmission? grind noise when starting is usually the starter or flywheel. a loose or broken bolt on the torque convertor or a cracked flex plate will make a knocking noise. I just don't know how anybody could tell you you need to replace your crankshaft without a tear down of the motor.
Old Sep 1, 2013 | 09:39 AM
IndianScout's Avatar
my auto made a grinding noise when started, I replaced the starter and all is good..
Old Sep 1, 2013 | 04:01 PM
Definitely need a "second opinion" on this one before blindly replacing the crankshaft.
Old Sep 2, 2013 | 07:47 AM
I definitely think so too... But its and automatic, I started it up yesterday and its more like a squeaky, squealing noise... It's definitely coming from the motor. Next time ill get a video and post the link.
Old Sep 2, 2013 | 08:13 AM
Ok here is a video I found on YouTube of another LT1 making the same noise as mine, hopes this helps what I was describing to you guys. Copy and paste it in your browser.
https://www.youtube.com/watch?v=6mHq...e_gdata_player
Sergio
Jan 27, 2016 04:27 PM
Jazsun
Dec 29, 2014 12:14 PM
chuyz28
Nov 25, 2014 11:14 PM
