Rebuild questions
Old Apr 21, 2003 | 03:32 PM
bad_Z's Avatar
Question Rebuild questions
Have a 93z with a 10lb vortec SC, Carrol water injection and superfueler. Engine was setup an 18k, 355cid, 9.1cr, forged pistons 1.5rockers, polished stock heads etc... A very similar setup as to Rkrauses' old setup...
Engine now has 55k, started to see some oil consumption about 10k back, and got worse about 3k back, decided to tear motor apart... Does anyone have any suggestions on what brand rings to go with, as well as any other details to go ahead and do as long as I have the motor torn apart?
Would also like to know a good break-in procedure
Any comments are greatly welcome,
thanks alot guys,
Michael
Old Apr 21, 2003 | 06:45 PM
kmook's Avatar
Advanced Tech Moderator
Lets try this in LT1 Tech first... moving.
Old Apr 21, 2003 | 06:53 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
40k miles is a good distance to ride on a build up like that.
I think the "break in" is more important than the brand though.
if you go with moly rings, they like to seat under high heat (beat the **** out of it when you rebuild it )
Noenav
Mar 1, 2019 07:38 AM
Sergio
Jan 27, 2016 04:27 PM
armedtrigger
Feb 24, 2015 08:30 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
