power loss and change in exhaust note
Old Apr 20, 2003 | 10:40 PM
bachehbad's Avatar
Ok during the past day ive been losing power and my exhaust note has changed. I also have hesitation and my c ar idles and accelerates VERY rough before 2000 RPM's i have no problems buying a new opti but i just want to make sure i'm not replacing a good part for another good part, any of you know ways i could check to see if it is my opti for sure?
Old Apr 21, 2003 | 12:57 AM
bachehbad's Avatar
no one is an expert when it comes to the opti???
Old Apr 21, 2003 | 01:04 AM
Jcb890's Avatar
i know its not the same, but this happened to my friend's Ram...pretty much the same thing happening as u have. he replaced the cat and it was better. might b the cat, might not, hope this helps...
take it easy,
jake
Old Apr 21, 2003 | 01:13 AM
bachehbad's Avatar
what other symptoms do youe get from a clogged/bad cat???
Old Apr 21, 2003 | 01:25 AM
NineSevenWS6's Avatar
higher engien temps? check the cat after a nice long drive, it might be 'glowing red'...
Old Apr 21, 2003 | 01:34 AM
bachehbad's Avatar
the engine temp is a bit high i think? it is at the halfway mark after a good long drive (15-20minutes)
Old Apr 21, 2003 | 01:42 AM
Rodrigues's Avatar
I had a similar experience, the car runs at different temps, sound changes, stuttering etc.. sounds like an opti
Old Apr 21, 2003 | 02:01 AM
GhostZ's Avatar
Why don't you check to see if you fried a wire or fouled a plug first before you go spending money on an opti.
Pop your hood at night with the car running and check for arcing...if you can't find a burnt wire, check your plugs. If the plugs aren't fouled run down to Auto Zone and have them hook you up to a scanner and check your O2 sensors to see if one is failed.
Might want to check the easy things instead of assuming opti of the get-go.
Old Apr 21, 2003 | 07:12 PM
bachehbad's Avatar
ghostz thanx for the tip, i found out it was a wire that was fried so one of my cylinders wasnt working.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
thenewkid
Nov 27, 2014 09:41 AM
