rebuild or modify?
Old Jan 9, 2006 | 09:31 PM
D_Liebel350's Avatar
rebuild or modify?
Just wanted some expert knowledge...what would make more sense and less money. there are a few things i get irritaded with so i thought of just rebuilding with new gaskets, wires, etc. or should i just start modifying with intent to weed out the problems. thanks for any imput.
Old Jan 9, 2006 | 10:28 PM
1racerdude's Avatar
Re: rebuild or modify?
UH--- What problems?
Old Jan 10, 2006 | 01:43 AM
aggiez28's Avatar
wrong forum bud, go check out the rules at the top of the page
brook
Old Feb 1, 2006 | 04:17 PM
this is the LT1/LT4 tech page isnt it
Old Feb 1, 2006 | 04:31 PM
Stoopalini's Avatar
I don't really understand what you are asking. Can you clarify your question for us?
By rebuild, do you mean pull the motor out, bore out the cylinders, replace pistons, new cam, head work, etc, etc ... or do you mean a tune up with plugs, wires, and some new gaskets
And by modify to weed out problems, what exactly do you mean there?
Old Feb 1, 2006 | 04:32 PM
Steve0's Avatar
It would help to know what kind of problems the car has. Generally, you wouldnt want to rebuild a motor unless you were having problems with the motor's internals.
Old Feb 9, 2006 | 10:16 PM
well to clarify all questions i will tell...the problems i am having are as follows
first off sometimes i have had the got kinda bog down for some reason and it feels like it is going to die (10-0 mph), then when i take off again it runs fine and then stays that way, this happens bout once every 7-10 days and i drive it a couple miles a day maybe.
next whenever it gets hot the tranny shifts ( 1 & 2) jerks really hard no matter what speed, i let it sit and cool down its fine.
also i have been have small leaks which in turn seem to lead to gasket replacement
and then again i would like to do your "complete rebuild" with cam, heads, intake, headers etc...thought about the LT4 package
hopefuly that has answer your questions
Old Feb 9, 2006 | 10:26 PM
TheNuge876's Avatar
Check the plugs and wires etc. Do some basic tune up stuff first and then see how the car runs. Locate the source of leaks and see if you can replace the gaskets, shouldn't be too hard to do yourself. Check the condition and level of trans fluid might help to have it flushed and replaced. But depending on mileage etc. It may just need a tune up and then you'll be good to go
Old Feb 10, 2006 | 05:41 AM
Guest47904's Avatar
Guest
The problem with modding when you have problems is you may never know if the mod is done correctly unless it's running correctly(depending on the mod of course).
It would be best to fix it first then mod it. Also get a scanner of some sort and learn it inside and out. For example, you could have a code right now and not even know it. Several codes do NOT set the SES. The fact that you have an OBDII doesn't help simplify things either.
Old Feb 10, 2006 | 03:38 PM
"White Knight"'s Avatar
lol. Don't do anything yet. Search around and don't just buy the LT4 package. There are a few porters who post here that do exellent work and can get you more than the LT4 package can. Just research a little while until you really see what direction you want to go and what kindof budget you have. If you just want to commute on this thing then just fix it, you don't need a new motor. The hesitation/bog is probably a tune-up problem.
Money is what decides everything........first find out your budget.
Old Feb 10, 2006 | 06:27 PM
Z28Freak86's Avatar
I agree with White Night, Dont really get into the lt4 package. It sounds like a tune up may be the answer, but check into it alittle deeper. Once you find the problem, figure out how much u need to fix it. Theres really no need in spending alot of money on a new rebuild if you dont need to do it. As far as the lt4 package is concerned, there are alot more bolt on options that would give you much more hp at a cheaper price.
marlar98
Sep 12, 2018 07:18 AM
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
Ks0209
Oct 1, 2015 07:32 AM
Bxlt1
Sep 29, 2015 03:18 PM
