Rearend noise? Is this bad?
Old Aug 7, 2003 | 07:56 AM
racinmyz28's Avatar
Unhappy Rearend noise? Is this bad?
Hello all,
I just installed a new 10 bolt rearend with a aftermarket auburn posi and 4.10 gears. They guy I bought it from said that it was already setup and working perfectly. When he shipped it to me, he removed the axles and all the fluid for shipment, I put everything back to together and when I started to drive it, there is a slight to moderate whine when I let off the gas between 40mph to 0mph. I havn't driven it faster the 40 mph because I don't want to damage the rearend further.. I have only put 10 miles on it since installation (most below 25mph).
I have herd the 4.10 gears are noisy. I also have a complete suspension setup with a Sphon TQ arm, aluminum driveshaft, LCA, LCA relocations, panhard.. I have royal purple gear oil, and GM posi additive.
Is this normal.. any help is appricated.
Old Aug 7, 2003 | 08:17 AM
IDOXLR8's Avatar
The whine usually occurs when the rearend was not setup properly. Do you know what brand the gears are?? Richmond gears are infamous for whinning.
Old Aug 7, 2003 | 08:19 AM
racinmyz28's Avatar
Arrow Gear make?
Well, I am not sure who makes the gears, but if they are richmond, should I worry about it, or drive it as is.. I will email the guy to find out. There is no whining when I am under throttle, only when i take my foot of the gas and let it cost.
Old Aug 7, 2003 | 08:40 AM
97FormulaWS-6's Avatar
I would say it's either the "normal" gear whine or your pinion depth is set incorrectly..
check out this link...
http://www.dippy.org/svcman/sm03.html
it's got some good rear-axle info on gears...
Old Aug 7, 2003 | 09:12 AM
racinmyz28's Avatar
Thanks for the info
Thanks everyone, is there any way to reset the pinion depth without taking it to a shop? as in, could I do it?
Any help is appricated
Old Aug 7, 2003 | 10:12 AM
Resetting it isn't an easy thing to do...
For most people I'd have a reputable shop listen to it and then if they think something is up have them check it.
kxrawx
May 25, 2015 08:29 PM
Zuvell
May 15, 2015 08:18 PM
Fatdog2
Feb 12, 2015 12:24 PM
ddr698
Jan 9, 2015 10:05 AM
squarehead
Nov 21, 2014 08:02 PM
