Rear making noise when turning.....
Old Apr 10, 2003 | 12:11 AM
James3219's Avatar
My rear is making a noise when ever I make a big or sharp turn. A freind suggested that I need some rear axel grease and some limited slip fluid. I bought this rear used and had it put on about 2 months ago. Could the fluid be low that is making the noise. Thanks.
Old Apr 10, 2003 | 12:16 AM
ramair96ws6's Avatar
my rear did this once. i changed the fluid and used mobil 1 80-90 oil and a tube of the limited slip additive from gm this is the best stuff out there and all the noise went away. If you use the stuff from uto zone or checkers it will still make the noise you have to use the stuff from gm i dont know why but it works and for 6 or 7 bucks its well worth it in my opinion
good luck
Steve
Old Apr 10, 2003 | 12:17 AM
pennys58's Avatar
this is a reply to a question that I posted a while back, however, it is the front that is making the screeching noise on mine...this is the solution to the problem that is describe for the back...first for starters....
the loud scretch you hear when your turn a corner is your axle shaft comming out of the axle..your rotor closes the distance on your caliper and thats it you hear scrrrrrrrrrrrrrrrrrrrrreeeeetch.
your c-clips are worn out inside your differential...replace these and your good to go..no more play in your axle shafts.
BTW you can verify this by jacking up the car and tugging on the rear wheels if they move more than 1/4 of an inch ..the clips are worn..
Hope this helps.
Old Apr 10, 2003 | 12:20 AM
James3219's Avatar
It's not really a skreetch, it's more of a whoooooo. lol Kinda hard to explain how it sounds.
Old Apr 10, 2003 | 12:31 AM
pennys58's Avatar
Like the sound a truck with 38's cruising down the highway at 80 makes?
Old Apr 13, 2003 | 03:37 PM
James3219's Avatar
OK, Where is the little plug located so I can pour the grease in there?
Old Apr 13, 2003 | 04:04 PM
Bryan Smith's Avatar
http://www.bfranker.badz28.com/fbody/maint14.jpg
Right there.
I need to pick some LSD my rear whines and pops when I turn. heh
Old Apr 13, 2003 | 04:50 PM
James3219's Avatar
Thanks for the picture. But now I don't have an allen wrench big enough to get it off. I have 2, one is too big, one is too small. Nothing is ever easy for me. Does anyone know what size wrench I need. I am gonna have to go buy one, or maybe a whole set.
Old Apr 13, 2003 | 04:55 PM
Actually I just used my socket wrench without a socket on it, worked fine. (I was in a pinch, drained rearend and didnt have another car to get a real wrench needed)
Old Apr 13, 2003 | 04:56 PM
LS1_03's Avatar
If you have a ratchet and an extension, you should be able to get it off.
Old Apr 13, 2003 | 04:57 PM
Mtrhds94Z's Avatar
A reg 3/8" square drive goes into that plug...
Old Apr 13, 2003 | 05:17 PM
James3219's Avatar
Doh. I knew it would be something simple. Thanks guys.
Old May 23, 2003 | 01:27 PM
SweetZRag's Avatar
Hope this helps.
Pennys58,
I am having the problem (and sound) you described. A screeech when I make a hard turn from the left rear wheel area. I just put new rear brakes and rotors so I thought maybe I did something wrong. I do have about 1/4 play when I pull in and out on the axle.
I am going to check the C clips as you suggested. Anything else I should check based on your experience?
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
