Rear main seal. What piece is this?
Old Dec 4, 2007 | 02:58 PM
marshall93z's Avatar
On the right. I have no clue where that goes?!
Old Dec 4, 2007 | 03:12 PM
wht-z's Avatar
That Is The Rear Main Housing Gasket
Old Dec 4, 2007 | 03:13 PM
Javier97Z28's Avatar
Moderator
If you're just doing the rear main seal you don't use either of the two gaskets on the left... those are for the housing itself.
Old Dec 4, 2007 | 03:18 PM
Wait, I'm confused. The one on the very left goes inside the housing. The one in the middle goes between the housing and the block. Where the hell does the one on the right go?
I don't see anything NEAR the back of the block with that many holes in it!
Old Dec 4, 2007 | 03:25 PM
I don't see it on shoebox's picture either?
Old Dec 4, 2007 | 04:16 PM
n2ceptor's Avatar
Its probably a universal gasket set with different application, thats why the extra gasket...
1 kit fits all......
Old Dec 4, 2007 | 04:39 PM
I guess, because I can't find anywhere to put it!
Old Dec 4, 2007 | 04:44 PM
mdacton's Avatar
Its for a different kit. don't worry about it. I never use the adapter to block seal I just put silicone on it
Old Dec 4, 2007 | 04:53 PM
Now I'm curious! What kit IS it for?
Old Dec 4, 2007 | 04:56 PM
mdacton's Avatar
probly a dsl. conversion 350 or something 6.3L
Old Dec 4, 2007 | 05:02 PM
Hmmm...
Old Dec 4, 2007 | 07:03 PM
jclark311's Avatar
Other GM motors use that same seal housing, my friend was doing the crank on a 4.3 liter chevy blazer, and i would swear it had that same housing, but it used the full gasket. Its just a gasket for another GM application.
Old Dec 4, 2007 | 07:28 PM
greenmachinedriver's Avatar
your freinds 4.3 blaze probably was the same part number as an lt1 a 4.3 is almost exactly the same as a 350 just missing two cylinders. bore, stroke, rod length, timing chain, rockers pushrods, all the same.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Dec 4, 2014 11:56 AM
