Rear Main Seal Leaking
Old Jun 13, 2008 | 11:20 AM
Dadic 78's Avatar
How complex a job is a rear main seal replacement? I've just noticed the past couple days my main seal is dribbling oil on the driveway... Car's a 1994 M6.
Old Jun 13, 2008 | 11:31 AM
ulakovic22's Avatar
Replacing it is stright forward, but the job itself is time consuming and can be hard if you don't have the right tools. Are you sure it's the RMS? Could it be something higher that is just leaking down?
Old Jun 13, 2008 | 12:10 PM
Dadic 78's Avatar
I've gotta get underneath it, and have a close look... I'll do that next weekend when I swap plugs. For now I'm just looking at the "usual suspects" and getting informed.
Old Jun 13, 2008 | 12:30 PM
Dave1980's Avatar
Well alot of people mistake the rear main leak for a rear intake leak dribbling down, just FYI.
Old Jun 13, 2008 | 03:15 PM
Dadic 78's Avatar
^^^ Cool man, I'll check it out, and get back.
Old Jun 13, 2008 | 07:00 PM
evilundisguised's Avatar
FYI
http://www.microsleeve.com/csrs.html
Old Jun 17, 2008 | 05:29 AM
Guest47904's Avatar
Guest
Intake usually as mentioned above. The main seal can be dealt with using high mileage oil which contains more swelling agent than conventional oil. Give it a try.
Old Jun 17, 2008 | 06:26 AM
kaboiz's Avatar
When I bought my car and looked underneath and saw all the class 2 oil leak, my initial thought was the rear main also, but after pulling the engine and taking a gander, it turned out to be the rear portion of the head and intake manifold gasket. The oil was leaking from the top, in between the engind and bell housing and coming out the bottom between the engine and bell housing as well as all over the outside of the bell housing and engine. One big mess!
So I pulled the whole engine/transmission....just to see if I could and to replace what needed replacin' Now that I have it out, I might as well replace the rear main...but I have just one question: Can the rear main seal be replaced without pulling the oil pan?
Old Jun 17, 2008 | 02:24 PM
Dave1980's Avatar
Of course, I replaced mine when i did my clutch a few years back. I just put a new one on my build also.
Old Jun 18, 2008 | 07:40 AM
95Blackhawk's Avatar
Damn, you are committed! Might as well do mods with the engine out.
Old Jun 18, 2008 | 08:15 AM
CANTONRACER's Avatar
I thought my real main was leaking a few years ago. Just in case it was the intake, I took it off, made it seal well...did that twice just in case.
No luck.
I pulled the motor because I had some concerns and guess what, it was not the rear main...it was the freeze plug at the back of the cam that was leaking.
It would have pissed me off to swap the rear main..it would have still leaked.
HectorM52
Jul 30, 2017 11:46 AM
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
redleader
Jan 22, 2015 12:05 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
squarehead
Nov 21, 2014 08:02 PM
