rear main seal, how much to fix?
Old Sep 3, 2004 | 05:18 PM
st08x's Avatar
how much is it have a shop replace the rear main seal? its not leaking much but its freakin annoying, everytime i get out of my car there is the smell of burning oil and u can see the smoke from the oil at night, it doesnt leak too much though, maybe onl 2 drops on the ground if it sits all night... it is just really starting to **** me off...
Old Sep 3, 2004 | 05:23 PM
Kataklysm's Avatar
Re: rear main seal, how much to fix?
Well to get to it they need to drop the tranny so expect to pay quite a bit...the part is like $30-50 its the labor thats killer.
Old Sep 3, 2004 | 05:24 PM
n2ceptor's Avatar
most shops are around 50+ dollars an hour.... Your looking at 4-6 hours of work... Not including parts....
Old Sep 3, 2004 | 05:47 PM
st08x's Avatar
well crap...so its like a few days of work if the shop is lazy?
Old Sep 3, 2004 | 05:57 PM
Fux0redImages's Avatar
well, i know that at my shop to install a torque converter, book time is 2.5 hours @ $70/hr. you basiclly have to do the same thing for a rear main seal. except when you drop the tranny, you take off the flywheel, take out your seal, then put the new one in and put it all back together. anyone with the least bit of common sense should be able to do a rear main seal on a RWD vehicle.
Old Sep 3, 2004 | 06:48 PM
Kataklysm's Avatar
Wow thats cheap, around here minimum is $70ish
Old Sep 3, 2004 | 07:12 PM
LilJayV10's Avatar
we'd charge about 200-250 for it, and would replace the trans front pump seal while the tranny is out, if it's an auto.
Old Sep 3, 2004 | 07:26 PM
n2ceptor's Avatar
Thats not counting dealerships.... They take you for a ride...
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
squarehead
Nov 21, 2014 08:02 PM
