Rear end whine
Old Jul 14, 2003 | 10:12 AM
Bens94Z28's Avatar
Exclamation Rear end whine
i have a 94M6,
i put 4.10's in the rear and there is a loud whine from the rear end, i took the car back and they said that with a gear like 4.10 'some' whine is normal. the car seems fine accept for the noise, should i persue the problem further or just ignore the whine?
p.s. i have a 2 serries carrier since the car USED to be an A4 and the gears are richmond
Old Jul 14, 2003 | 10:18 AM
FacelessZ's Avatar
Did you get the 'soft' ring and pinion or the 'hardened'?
Old Jul 14, 2003 | 10:20 AM
Bens94Z28's Avatar
i have no idea.
i didnt know there was a difference,
depending on which one i have, (i will call summit where i got them) is the whine normal?
Old Jul 14, 2003 | 10:30 AM
FacelessZ's Avatar
The whine is normal for the hardened set...the softer gear set, which isn't as durable, the whine is lessened but not eliminated
The whine is perfectly normal, especially with 4.10's
Old Jul 14, 2003 | 10:44 AM
TechCam97's Avatar
Yea, the whine is normal for those gears. Especially if you have the hardened set. My friend has them in his 97 SS and it whines a bit as well. Just turn up the stereo and nail the gas!
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
