Rear- end for Lt1
Old Feb 24, 2003 | 03:58 PM
DCam's Avatar
Rear- end for Lt1
i was wondering. I have a 95 Lt1 and was looking at a rear-end from and Ls1 with 4.10's to swap into my car i was wondering if i would have to do any modifying such as spacing and if the ABS and all electronic hook ups(speed censor) would work.
Old Feb 24, 2003 | 05:05 PM
CamaroBoy96Z28's Avatar
The rear ends are basically the same i believe, someone correct me if im wrong....also the ABS is a 4 series carrier? instead of a 3 series like the LT1. HTH
Old Feb 24, 2003 | 05:17 PM
I think you are confusing differential "carriers" with ABS "channels". The LT1 and LS1 rears all use 2-series carriers for 2.73's, and 3-series carriers for anything higher (numerically) than that.
And, both LT1 and LS1 rear axles were available in 3-channel (no traction control) and 4-channel (tractional control) versions.
The brakes are the main difference. You should be able to swap, as long as you get the correct number of ABS channels. 3-channel will have a single sensor in the diff housing. 4-channel will have a sensor in each brake backing plate.
Old Feb 24, 2003 | 09:52 PM
DCam's Avatar
rea-end
thanks for the info injuneer i think i am going to get a 10 bolt with 4.10's off of a 1999 Z28 Ls1 so i will make sure it is a 4 channel because i know i have traction control
oldschool
Feb 9, 2016 09:21 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
Hurin
Dec 13, 2014 07:38 PM
