Rear End Help
Old Jul 28, 2003 | 01:50 PM
POSSESSEDZ's Avatar
Rear End Help
I decided on the motor and trans i want to rebuild thanks to this site. Now i need help in deciding on the rear end can the stock one be built to handle around 450rwhp or should i go 9 or 12 bolt moser or if there are any more ideas,It will be very helpful.
Old Jul 28, 2003 | 02:02 PM
Depends on what tranny you have (A4's are easier on the rear), what kind of tires you use (slicks cause problems) and how you drive it. Treat an M6 with a little care and the stock rear will last. Try a few 6K clutch dumps with slicks, and you can kiss your rear goodbye.....
I personally prefer the 12-bolt to the Ford 9-inch. The 12-bolt is lighter, has a 3% better mechanical efficiency (less drive train HP losses), and "fits" better. The primary advantages of the 9-inch are that it is relatively easy to have a spare center section with a different gear ratio, and swap it out in an hour, and the ultimate strength is probably higher. Base model 12-bolt against base model 9-inch will probably not see any major strength difference. The Strange and Moser 12-bolts have been demonstrated to handle upwards of 900flywheelHP.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
