rear end gear
Old Apr 15, 2009 | 11:20 AM
94 355 lt1's Avatar
rear end gear
will 3.42 out of a 2001 work in a 1994
Old Apr 16, 2009 | 12:14 PM
94 355 lt1's Avatar
Old Apr 16, 2009 | 05:05 PM
JohnnyRage's Avatar
yes its the same rear end plug and play
Old Apr 16, 2009 | 06:37 PM
SkyChimp's Avatar
I'm new to learning the technical stuff about my 94 z28. Can anyone tell me the stock gear ratio for the rearend on this model?? I've heard everything from 3:23 to 2:73 Anyone know???
Old Apr 16, 2009 | 07:19 PM
jclark311's Avatar
Yes but the 01 has 4 channel ABS, and you have 3 channel ABS. You have 1 Wire running to a sensor on your readend pumkin, the 01 has 2 wires, one to each rear wheel. You may not be able to run the rear ABS. Do a search on this, other guys have done it.
Old Apr 16, 2009 | 07:29 PM
Kevin Blown 95 TA's Avatar
From the Drivetrain section...
3. What is a gear ratio, and how do I know what I have?
If your car's rear end is untouched, you can go by the RPO codes to find out what it came with. RPO codes are three digits, and are listed either in the door jamb or in the glove box.
GU2 = 2.73
GU5 = 3.23
GU6 = 3.42
And if you have the 2.73 and want to go to the 3.23 or higher, stock gears out of another car won't work without a compatable differential due to gear spacing caused by pinion gear size, otherwise you need the thicker aftermarket gear to go with your differential. If you have the performance 3.23 gear, then the other gears will just swap on there.
Old Apr 16, 2009 | 07:45 PM
SkyChimp's Avatar
Thanks Kevin, I really appreciate it.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
