Which rear do i have???
Old Feb 9, 2004 | 01:50 PM
guitardedjf's Avatar
I have a 94 z28 lt1 A4... Does anyone know which rear I should have??? I changed the gear oil last night, but i didn't know what to look for as i was looking at it to tell what size....
thanks for your help...
Old Feb 9, 2004 | 01:52 PM
ppmz28's Avatar
Look in the dash where the numbered sticker is(code) and look for GU2-2.73 or GU5-3.23, if you have 1,2,O,OD then I would say you have 3.23, but if you have 2,O,OD, then 2.73.
Old Feb 9, 2004 | 01:53 PM
Brundle's Avatar
should be 3.23s i believe
Old Feb 9, 2004 | 02:22 PM
Darn, you could have counted the teeth or looked at the stamping on the gears when you had it open.
Old Feb 9, 2004 | 02:25 PM
My95Z's Avatar
ppmz28 has it right on.. that is the eaiest way
Old Feb 9, 2004 | 02:31 PM
i DO have access to first gear, so i am thinking 3.23
but i'll check in the glove box too.
thanks guys!
Old Feb 9, 2004 | 02:32 PM
...unless they have been changed...
96SilverRam
Nov 20, 2016 11:19 AM
HarleyZ28
Oct 5, 2015 06:23 AM
BLK1997Z28
May 1, 2015 12:23 PM
thenewkid
Apr 12, 2015 07:42 PM
