Rear Distributor Conversion... (Carbed LT1)
I'm swapping to carbed for a 383 stroker...
I was told I'll need a .184" x .680" key on the crank snout and a 6.75" damper because of the opti drive delete plug plate...
How/where can I get these items, and does this completely eliminate my current crank hub?
Any info would be great. Thanks...
-Garrett
-Garrett
I have done the swap, but i dont know about the crank becuase i just decided to leave to the opti on, i plan on taking it off soon though. You can get the opti delete plate from a dealership, its in the performance parts catalogue. Your gonna need a new hood also if you use the GM carb'd intake. Hopefully someone will be able to help you better, i would also be interested to know the answer to that.
I am putting the engine into a different car, not an fbody...
Also, I have already ordered teh opti plug plate with timing mark... That is the problem. The plate thing doesn't clear the stock balancer, so a smaller diameter one is needed. I'm nut sure what reason there is for the new key, but I have been told I'll need it...
Alright, I'll see what I can find...
not to keep beating on the subject, but what should this key look like? A big oversized washer? Is this "key" equivalent to the hub I currently use to hold the stock balancer?
Thanks a lot by they way, you've really helped out...
-Garrett
-Garrett
Look over this write-up of Dave's for some info.
Thanks for the link. I understand now...
I do have a new question now though. He was putting a stock diameter dampner on... Am I going to have any strange effects due to using a 6.75" dampner instead?
I know the tensioner will probably take care of the belt slack, but what about charging and water pump issues, won't it be spinning a lot faster with the smaller crank balancer?
