Rear Distributor Conversion... (Carbed LT1)
Old Jun 20, 2004 | 10:50 PM
hot_red_z28's Avatar
I'm swapping to carbed for a 383 stroker...
I was told I'll need a .184" x .680" key on the crank snout and a 6.75" damper because of the opti drive delete plug plate...
How/where can I get these items, and does this completely eliminate my current crank hub?
Any info would be great. Thanks...
-Garrett
Old Jun 21, 2004 | 04:39 PM
TTT, please, someone has to have done a carb swap before...
Old Jun 21, 2004 | 05:02 PM
Geoffmj's Avatar
I have done the swap, but i dont know about the crank becuase i just decided to leave to the opti on, i plan on taking it off soon though. You can get the opti delete plate from a dealership, its in the performance parts catalogue. Your gonna need a new hood also if you use the GM carb'd intake. Hopefully someone will be able to help you better, i would also be interested to know the answer to that.
Old Jun 21, 2004 | 05:25 PM
I am putting the engine into a different car, not an fbody...
Also, I have already ordered teh opti plug plate with timing mark... That is the problem. The plate thing doesn't clear the stock balancer, so a smaller diameter one is needed. I'm nut sure what reason there is for the new key, but I have been told I'll need it...
Old Jun 21, 2004 | 06:47 PM
You probably need a key for the standard balancer, because the stock LT1 uses no key.
Old Jun 21, 2004 | 06:54 PM
What does it take to get one of those put in/on. Would a machine shop have to do it?
Old Jun 21, 2004 | 07:03 PM
Crank key? You just tap it in with a mallet.
Old Jun 21, 2004 | 07:05 PM
sounds good to me...
where could I get something like that? any ideas?
Old Jun 21, 2004 | 07:08 PM
Machine shop, parts store, speed shop, dealer...
Old Jun 21, 2004 | 07:13 PM
Alright, I'll see what I can find...
not to keep beating on the subject, but what should this key look like? A big oversized washer? Is this "key" equivalent to the hub I currently use to hold the stock balancer?
Thanks a lot by they way, you've really helped out...
-Garrett
Old Jun 21, 2004 | 07:24 PM
Look over this write-up of Dave's for some info.
Old Jun 21, 2004 | 07:44 PM
Thanks for the link. I understand now...
I do have a new question now though. He was putting a stock diameter dampner on... Am I going to have any strange effects due to using a 6.75" dampner instead?
I know the tensioner will probably take care of the belt slack, but what about charging and water pump issues, won't it be spinning a lot faster with the smaller crank balancer?
InfernalVortex
Jan 17, 2015 09:35 AM
brentbrowning01
Dec 3, 2014 10:36 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
