Rear Distributor - Carb Conversion
Old Apr 2, 2006 | 01:56 PM
snod83's Avatar
I am changing my car over to a carb and rear distributor (I think, still deciding) and I have done a search here but have been unable to answer a few of my questions.
First, I would like to see some pictures of how the carb, distributor, and air filter all fit together. I know clearance will be tight, but I have a 3" cowl hood already, so air filter clearance shouldn't be a problem.
Second, I was wondering if anyone has any idea how much I will have to cut the cowl area to get a distributor to drop in place easily? Is it necessary to install the distributor and intake at the same time?
Thanks for the comments on this, and please, if you don't have anything nice to say, don't say anything at all. I am a carb guy at heart and I have grown to hate fuel injection.... (I know all its benefits)
Ryan
Old Apr 2, 2006 | 02:39 PM
FastZinTennessee's Avatar
Re: Rear Distributor - Carb Conversion
I remember hearing you can use a low profile style distributor and it will work under the cowl without cutting. You won't be able to remove it in the car anyway so I'd go that route if you find out something definite.
Old Apr 3, 2006 | 09:22 AM
snod83's Avatar
I was actually looking for something that can be done with the motor in the car. I am pretty sure someone here has done it in the car!
Thanks,
Ryan
Old Apr 3, 2006 | 09:28 AM
streetrod93's Avatar
the distributor doesn't pose the problem....depending on the size of your carbuerator (ie. dominator 1050) i know you'll have to cut the cowl for that to fit, unless you mount it horizontally
Old Apr 3, 2006 | 11:39 AM
snod83's Avatar
Well, I am actually considering a demon or holley 750cfm carb. I am sure I will have to cut the front of the cowl for it, but I was wondering if its necessary to cut the cowl so that the distributor can be removed (actually installed) with the engine in the car.
Thanks again,
Ryan
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
HarleyZ28
Oct 5, 2015 06:23 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
