rear diff problems
Old Mar 13, 2004 | 04:54 PM
gtheftz28's Avatar
rear diff problems
ok so i just had the rear pinion gasket replaced. After getting the car back i notice when i am backin up with the sreering wheel turned all the way that it makes a clicking sound like the driveshaft is sticking on something. also, after the sound, a spray of rear diff fluid is stuck on the ground like it was sprayed on there from the diff. any ideas?
Old Mar 13, 2004 | 04:57 PM
jakesnake123957's Avatar
Look under there and see whats up,good luck.
Old Mar 13, 2004 | 04:59 PM
gtheftz28's Avatar
i have looked, cant see anything right now, cept for the fluid that sprayed everywhere. I am wondering if adding some limited slip additive to it would make a difference. It is posi
Old Mar 14, 2004 | 03:57 PM
gtheftz28's Avatar
any suggestions?
Old Mar 14, 2004 | 04:04 PM
Scream And Fly's Avatar
You MUST have the posi additive in the rear diff fluid or it will certainly make that clunking noise.
Mine did the same exact thing - was really loud sounding too. I changed the rear diff fluid and used the GM additive - all gone!
Not saying this is your problem, but if sounds like it could be. Easy fix too.
Greg
Old Mar 14, 2004 | 04:07 PM
gtheftz28's Avatar
did it sound like the driveshaft was clinking on something?
oh yea is it bad for the diff???
Old Mar 14, 2004 | 04:10 PM
Yeah, and it got progressively louder until I did something about it. Many shops will not add the GM additive when changing your diff fluid. I checked everything - turns out the previous owner didn't add it either. Once I changed the fluid with the additive, it was perfect. Towed boats many thousands of miles with the Z since - no problem!
Ask the shop if they used the additive, but I bet they didn't.
Greg
Old Mar 14, 2004 | 04:12 PM
gtheftz28's Avatar
they didnt. why wouldnt they? thats kinda dumb. but im ok driving it until i bring it into the shop tomorow? i was just wondering if missing the additive would cause that. did yours sray diff fluid when it clunked?
Old Mar 14, 2004 | 04:15 PM
Well, mine didn't leak at all. Are you sure yours is leaking? Maybe that oil on the diff is from when they changed it?
Believe it or not, MANY places won't add the GM additive unless you request it. You need it, or it will make noises. You'll be fine driving it for now though.
Greg
Old Mar 14, 2004 | 04:18 PM
gtheftz28's Avatar
thanks buddy
Old Mar 14, 2004 | 04:24 PM
No problem... Let me know how it works out. I know I kinda' freaked when I first started hearing those sounds.
Greg
jcamaro95lt1
Jan 24, 2015 08:21 AM
ddr698
Jan 9, 2015 10:05 AM
siguy
Nov 27, 2014 10:07 AM
slothgrant
Aug 22, 2002 03:01 PM
