Rear brake replacement? (quick question)
Old Jul 16, 2003 | 08:49 AM
vodoo-chile's Avatar
Question Rear brake replacement? (quick question)
Are there any special tools needed to replace the rear pads on our cars? I have done plenty of front discs and rear drums but have never done any rear discs before. Anything I should look out for? Thanks in advance,
Kyle
Old Jul 16, 2003 | 08:51 AM
No special tools needed. If in doubt, do one side at a time, so you have the other side for reference, in case you get stuck.
Old Jul 16, 2003 | 03:35 PM
Thanks Shoebox. I saw the blow ups of teh calipers and mounting brackets on your site. Thnaks!!! Do you know of any install guides or am I really making this a bigger deal than I have to? Thanks again,
Kyle
Old Jul 16, 2003 | 04:07 PM
Don't know of a guide, but it is not all that hard. You might want to have a big c-clamp (like 6") handy to compress the pistion. Leave the old inboard pad on when you compress it. You will need to do this to get it back over the rotor with the new pads. Pay attention to the "H" clip and put it back like you found it (hopefully it was in the right place ).
Old Jul 16, 2003 | 05:27 PM
So is it simialr to a front disc brake setup? If so, no problem.
Kyle
Old Jul 16, 2003 | 05:36 PM
naztyz28's Avatar
ya watch out for them "H" clips mine where rusted off and i cant find replacements anywhere anyone know where i can get them? thinking this is my proublem with rear brakes making alot of noise.. but anyway what he said very easy to do..
Old Jul 16, 2003 | 05:39 PM
snorkelface's Avatar
I think they include that in the caliper rebuild kit. It's pretty cheap kit at Autozone.
Old Jul 16, 2003 | 07:36 PM
I'm not wanting to "rebuild" anything. I just really want to replace the pads and put it all back together. Is it still fairly easy?
Kyle
Old Jul 16, 2003 | 08:57 PM
Kyle
Yeah, it's still easy.
rear caliper pic 1
rear caliper pic 2
rear caliper pic 3
rear caliper pic 4
Old Jul 17, 2003 | 10:08 AM
Don't look at the word "rebuild" too harshly. The kit just includes stuff like the little metal retainers, rubber boots (I think) and so forth.
Old Jul 17, 2003 | 10:45 AM
Mikey97Z's Avatar
The litle H clips are just there so that the spring on the pad has a smooth surface to move against (smoother than the metal of the caliper). The inboard pad moves in and out with the piston and so that spring on the pad will rub against ~1/4" of that H clip track thingy. So shine it up and maybe put a spot of lube on it to keep things from binding and causing squeeking brakes!
Old Jul 17, 2003 | 04:53 PM
naztyz28's Avatar
well i need that H clips i dont have any and autozone kit dont have it anyone knoe where i can get them ???? thanks
Old Jul 17, 2003 | 08:22 PM
Well Shoebox, I finished the brajkes. I was going to do a write up, thinking there must be some people out there who could find some use of it. In all honesty, it was easier than the fronts so... It would take longer to write it up then it did to actually do the pads. It was two bolts per side to remove the caliper and then the big C-clamp to push the caliper in an open position. After that, I made sure the H-clips (thanks for the pics Shoebox) were inplace and popped the new pads in. Bolted it back up and done. Thanks to everyone for the advice,
Kyle
Old Jul 17, 2003 | 08:59 PM
... In all honesty, it was easier than the fronts so... It would take longer to write it up then it did to actually do the pads. ...
Kyle
That's probably the reason you don't see any write-ups.
Old Jul 30, 2003 | 09:57 PM
Cool ZR's Avatar
That kit you guys talk about from Autozone, who makes it? We don't have an Autozone in Canada that I am aware of... I checked with the dealer and the only way I can get that H clip is by buying the GM pad set... If you can remember who made the kit and the part number if possible, that would be great.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jazsun
Dec 29, 2014 12:14 PM
Hurin
Dec 13, 2014 07:38 PM
