Real bad stumbling, rough idle, Please Help
Old May 8, 2003 | 09:28 PM
Barry68Camaro's Avatar
Hey guys, I have a '94 Z A4. It has 57K miles. All stock except hooker cat-back. Car was running fine 'til tonight. I got in it, it started perfect. When I came to the first stop light, the car started to stumble or buck, not sure how to describe it (the engine was shaking the car). When I put the car in neutral, it clears up. I did notice the exhaust smelled pretty bad. I didn't get an SES light so I don't know what is wrong. I didn't get a chance to really get on it but it seems to run ok other than when first coming to a stop. Any ideas? Anything I should look for? You guys are awesome. I know I can always find great help here.
Old May 8, 2003 | 11:55 PM
Fatdog's Avatar
Cool
Might be the water pump going bad,and leaking down onto the distributor(opti).My02
Old May 8, 2003 | 11:57 PM
chasmanz28's Avatar
Re: Real bad stumbling, rough idle, Please Help
whens the last time the car had a basic tuneup? check the coil
Old May 9, 2003 | 01:12 AM
Wildwill532's Avatar
whats this damn coil im reading about does anyone have a picture so i know what i am looking to clean my car does the same damn thing, runs fine then the ses light flashes,
Old May 9, 2003 | 01:41 AM
chasmanz28's Avatar
whats the code yr getting?
Old May 9, 2003 | 01:49 AM
i dont know havent got it check, I know what the deal is Im sure its the opti or so because it rained like hell for a whole day and drive home after work fine lots of puddles but next day went nuts and freaked out
Old May 9, 2003 | 01:54 AM
chasmanz28's Avatar
well get it scanned at autozone they do it for free, that can be a start, just do the basic's, plugs, wires, fuel filter, check yr coil, could be bad or a bad connect, just pull the wire off and look to see if its dirty, wipe it clean and see what happens, if you do all the basic tuneups and yr still having a problem it most likey the opti
Fatdog2
Feb 13, 2015 08:19 PM
DetroitZ28
Feb 13, 2015 07:33 AM
Iamherefornow
Jan 26, 2015 04:57 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Dave19yz28
Jan 26, 2003 01:45 PM
