ready to blow up motor!!
Old Jul 14, 2007 | 08:14 PM
taubr unit's Avatar
Im ready to ****in blow my **** up!! So i replaced everything when i did my cam swap and i have a ticking noise comming from pass. side head. It started as no oil comming up from #4 piston and knocking. So put 2 and 2 toghter and theres the problem. WELL i took out the lifters and checked to see if it was clogged and it wasnt and clean so when i put it back i swaped it with another lifter to rule out a bad lifter. Put it back toghter and the "bad" lifter i put in a diff. hole was the first to lube the rocker and the orig. hole was now getting oil. So at that point everything was getting oil and well lubed...... ticking still there. So today i took my covers back off and that same rocker is now NOT getting oil again. WTF, and the ticking seems to be getting louder. Iv boggled all the minds of engine builders here, they just tell me time to rebuild. I got 60/40psi of oil pressure. Adj. the lifters anywhere from 1/8 to 2 full turns of preload and the noise doesnt change a tone. I swaped rockers with others.. same noise. This is complete garbage Heres what my vavletrain consists of......
gm847 cam------------new
ls7 lifters--------------new
magnum pushrods------new
promag rockers---------new
gmpp guideplates-------new
arp 7/16 studs---------used
beehive springs--------used
ti 10deg. retainers-----used
+.050 10deg. lock-----used
valve seals------------new
spring locators---------new
Old Jul 14, 2007 | 09:38 PM
Heatmaker's Avatar
Advanced Member
did you let the lifters soak before installing? Or are you installing them dry?
Old Jul 15, 2007 | 12:03 AM
06lingenfelter's Avatar
you spun a rod bearing i gaurentee it. i did the same thing. I thought i had a collapsed lifter and replaced everything with the hot cam kit. tick/knock was still there so i tore down the bottom end and sure enough it was a spun rod bearing. but yeah no oil coming to that cylinder and a new valvetrain but the knock still exist. i would put money on a spun beraing.
Old Jul 15, 2007 | 12:40 AM
urbaNHunter44's Avatar
your post is difficult to understand, but if you ran it long enough for it to start knocking with no oil in the #4 bearing I'd say you cooked it.
Old Jul 15, 2007 | 01:30 AM
turnin20s's Avatar
+1 for the spun bearing, sucks and I know....mine just got put back together.
Old Jul 15, 2007 | 02:18 AM
taubr unit's Avatar
ok so if its a spun rod bearing why would it do it from the inital start up? Right off the first start up it did it. Why would it do it then and not when it already had 100k on the motor? And if it was a spun bearing wouldnt i loose oil pressure?
Old Jul 15, 2007 | 07:48 AM
wrd1972's Avatar
Spun or burned bearings, could be rods or mains. Time to pull the motor. I would guess your bearing were on the edge of death and the new characteristics of the bigger cam drove the nail in the coffin. This happens a lot with cam swaps, the engine is used to the stock cam then sees something a tone bigger IE: the 847 so somethings gotta give. Could also have been some contamination that made it an oil gallery.
Knowing what I know now I would never install a bigger cam without pulling the motor to replace all bearings. You can have a single bad bearing and not drop the oil pressure significantly BTW.
Drain the oil and look for shavings. If its bearings then the evidence should be there.
Old Jul 15, 2007 | 08:12 AM
mdacton's Avatar
sounds like a lifter to me.......if it was a bearing or piston pin then you should be able to here it. Put your old lifters back in it
Old Jul 15, 2007 | 10:46 AM
taubr unit's Avatar
well it did the noise with the old lifters too so thats why i bought new ones. Now when i first start my car the noise it barely there and when it warms up it gets louder too. And i drive it and it drives fine but does feel like it has a flat spot in the power curve at like 4k and up. So i guess when all else fails i run the car and when something gives then i found my problem, lol.
Old Jul 15, 2007 | 08:36 PM
taubr unit's Avatar
I THINK I FIXED IT!!!!!!!
In the whole process i noticed more then normal rubbing on the one pushrod. So i took off the studs and inspected the guideplate. And wouldnt ya know, the noisey one had rubbed away some material away from the guideplate. So i put it back on and got the guideplate as low as i could get it and tighted it down. Ticking gone and now getting oil!! And you cant move the plates very much thats why i never checked it but like the saying goes "a little dab will do ya" cause the .00001in. i moved it, it went away. Im crossing my fingers untill tomm. when i could run the car more and really be sure. But as of right now its all good!!!
Old Jul 15, 2007 | 09:36 PM
mdacton's Avatar
seems like alot of people have problems with the gmpp guide plates
F'n1996Z28SS
Aug 23, 2023 11:19 PM
armedtrigger
Feb 24, 2015 08:30 PM
blac94Z
Feb 18, 2015 11:36 AM
Snoman73
Nov 17, 2014 07:22 PM
