Re-using stock heads with rebuild.
Old Aug 6, 2005 | 07:36 PM
Birdman7389's Avatar
Spun a bearing at 69K. Planning on using the same heads on the rebuild.
I was thinking of dissasembling them, takin them to the machine shop to ensure they are flat, and reassembling with the same valves, new springs retainers locks and seals.
Good idea? Anything else I should be concerned or aware of?
Old Aug 6, 2005 | 08:06 PM
FastZinTennessee's Avatar
Re: Re-using stock heads with rebuild.
You could have them milled a little and use a thinner headgasket for a small bump in compression. You'll probably want to have them milled anyway to have a perfectly flat sealing surface for when you put it back together. Three angle valve job will help out flow a hair. Ever thought about finding someone local to do a basic gasket match and pocket port?
Old Aug 6, 2005 | 08:37 PM
1racerdude's Avatar
Heads should have a rebuild and valve job.
Old Aug 6, 2005 | 08:48 PM
Hmm, maybe a LE1 job would be the best way to go...
Old Aug 6, 2005 | 09:41 PM
NVetro's Avatar
and so the snow ball effect begins
Old Aug 6, 2005 | 10:57 PM
I know
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
Killer94z
Jan 13, 2015 12:06 PM
Brian-94TA
Jul 31, 2002 02:52 PM
