re-route fuel lines?
Old May 21, 2006 | 08:52 PM
gbu27's Avatar
I got my LT headers and ORY y pipe installed, i want to have mini cats i bought installed on the ORY pipe, i have a shop that has no prob welding them in. Except that the fuel lines on the driver side bottom of the car would be right on the fuel lines. Is there any way to fix that myself or does anyone know a shop around NC that would do something like that? thanks
Old May 21, 2006 | 11:10 PM
1995greenTA's Avatar
Re: re-route fuel lines?
with my pacesetter long tubes i had chambered mufflers directly on the headers which made them almost touching the fuel lines. I cut a piece of my old heat shield up and mounted it between the fuel lines and muffler. I posted basically the same question as you on here when doing this and got the answer of " it will be alright " from most of the people and didnt worry about it from then on. I had no problems. If you are the type to worry at all, i would look into moving them over a little bit. You may be able to do this with your hands and just bend them but i would be easy with them or not try it at all. just my thoughts, but who am i?
HectorM52
Jul 30, 2017 11:46 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
